What M/T Drag Radials Recommended for C6 Base Model with 750 RWHP
Guys keep in mind he has standard rear fenders so anything wider than 305 is going to rub unless he has some custom offset wheels.
Dennis I think the 305/35/18 M/T's are the hot ticket for those what want to run a DR on the street. Hoosiers cannot be run if there is any risk of a puddle, they are a full slick. M/T's have good siping and work pretty well in the rain until they get bald.
I have a wide rear, Coilovers, Pfadt sway bars, do you still feel the 310x17 Hoosier is the better tire for a 700 WHP set up like mine? I don't mind the look, as they'll strictly be used at the track.
Thanks again for sharing those videos.. Interesting that Stranger was dead hooking a stock 05 C-6, particularly because the 05 had a problem with the diff walls shattering when wheel hop or dead hook occurred. Probably the stock HP was show he got away with it, still awesome though!!!
Keith
Dennis, did you and Stranger pick up your 17" rear wheels at the same shop, or? Can you point me in the rig direction to find a set please?
Keith
Keith
I am getting ready to pull the trigger on buying Mickey Thompson Drag Radials for my Base Model C6 with Standard Rear fenders. The car makes 755 RWHP and I am looking at MT-3723R 28x12.5R19 Does the added tire Diameter hurt anything besides the Speedometer reading? Does this tire size work really well or should I go down to an 18" rim to gain sidewall? I would run 19-20 psi in the Drag Radials, What are my options to disable the Tire Pressure Sensor Alarm. Please give me your feedback!
Of course, at WOT on third-gear FWY pulls, the drag radials are nice.
Everything is a tradeoff. Good luck!
One thing nobody ever mentions about drag radials (not optional at your power anyway), but I thought I'd mention since this isn't a strip-only beast, is that a taller, larger sidewall tire is of course great for straight line performance, but it is at the expense of handling/cornering. I've never felt as confident in mine at high speed curves, say on a freeway interchange, as I was even on the $#!tty stock Goodyear Eagles. Not to mention, you can completely forget about driving in even the slightest rain. But an experienced drag guy probably already knows this.
They will handle what you see in the 1/4 maybe in the texas mile but are not speed rated to handle high speeds for a long distance in highway miles, I have seen a 185 blast on a daily basis going to the grocery store
I run 18" drag radials and the last around 8-10,000 miles on the street. My 60' is always in the 1.3 range and my car runs a pretty consistent 6.4- 6.3 sec 1/8 on pump gas.
M/T drag radials. 345/35-18
mlewis100 (01-19-2021)
It's because they weren't meant for the speed and more importantly duration of the mile. This rule was introduced around the time the Hinson vette rolled (which was on MT DR's).
I think Gary2004z06 runs the 305/19 Mickeys for street driving and even bracket events when he's not going for a record. Maybe he can chime in with some advice.
#33
When I made my passes at the Miami Mile I ran street tires for that very reason, I don't think DR's are made to go that fast that long.
180+ in my convertible Corvette.MP4 - YouTube
#35
So I guess I shouldnt be driving that fast on mine because I do daily, a quick blast to 185 from around a 30 mph roll coming off the circle, and have been faster then that for maybe 5-6 miles on the TP with 305x35x18 drs and skinnies and feels very comfortable, lots of guys are hitting those speeds in the 1/4 with Drs after doing a horrendous burnout creating more heat then just driving
Be careful out there! :-)
#36
Haters Gonna Hate but I went with Mickey Thompson Street Radials 305/35R19 on stock rims and stock suspension. No wheel hop and Hooks Awesome on the Street!
#38
Cruising
#39
Cruising
#40
Hi,sorry for my English,but,put one rear tmps in a PVC tube (4 inch long),cap one side (PVC glue) and drill a hole in the second cap for the second tmps valve tip and glue it .You have now a little pressure tank,wait 2hour to make sure it's dry and put the same pressure like front Wheel and your ECM won't see difference. Keep this tank in the trunk . I have M-T 305-35-19 on mine and everythings is ok. GM VARY
