tfs 255 rocker suggestions??
Old 08-21-2014, 06:55 PM
lsxvette
lsxvette's Avatar
Default tfs 255 rocker suggestions??
any suggestions on a set of rockers for the tfs 255 heads ? i bought a set of jesel from a forum member that was "supposed to fit all TFS heads" but they dont ..so im at square one again ... ive heard everything from jesel to stock ls3 with the trunion upgrade ..lmk what ya think
Old 08-21-2014, 07:02 PM
timd38
timd38's Avatar
What do you want to do with the car? I went with stock and comp Cams trunnions.
Old 08-21-2014, 07:04 PM
lsxvette
lsxvette's Avatar
its gonna be a 1000whp street car
Old 08-21-2014, 07:10 PM
timd38
timd38's Avatar
WOW, I have no clue than! Money buys speed and I don't have that much money!
Old 08-21-2014, 09:03 PM
NastyChevelle
5th Gear
NastyChevelle's Avatar
Crower makes a shaft set for those heads that I've used on two cars. Work great. I'd start there!
Old 08-22-2014, 12:40 PM
miami993c297
miami993c297's Avatar
Hi lsxvette,
The engine builder in charge of a "1000rwhp street car" project should be able to answer this basic question...
Christian
Old 08-23-2014, 12:13 AM
lsxvette
lsxvette's Avatar
Originally Posted by miami993c297
Hi lsxvette,
Christian
thanx for the words of wizdom but i would rather make my own decision thats why i ask more then just "the engine builder" theirs nothing "basic" about a 1000rwhp build
Old 08-24-2014, 07:03 AM
BOO666
BOO666's Avatar
T& D fan here .... I had same heads and stock rockers with no issues . Get the right person on those heads and they make great power . T .E . A. Built mine .
Old 08-24-2014, 08:22 AM
timd38
timd38's Avatar
Let us know how your R&D project turns out! Sounds like fun.
Old 08-24-2014, 01:44 PM
lt1z
lt1z's Avatar
Stock with comp trunion upgrade and the TFS supplied rocker stands. Keep lift below .630 and let the PA do the work. You don't need a shaft rocker and solid roller valve train for 1000 hp unless you are trying to do it N/A or with a small shot.
Old 08-25-2014, 04:31 PM
lsxvette
lsxvette's Avatar
yea some very knowlegable people told me the same thing ..im gonna give it a shot
Old 05-19-2018, 10:54 AM
Bigwebb
Bigwebb's Avatar
I'm looking for information on the same question... The only difference being I am looking for 510-20ish rwhp
Old 05-19-2018, 11:19 AM
Brandon619
Support Corvetteforum!
Brandon619's Avatar
Run Yella Terra rockers from Tony Mamo and be done.
Old 05-19-2018, 03:34 PM
Bigwebb
Bigwebb's Avatar
this is the yella terra yt6733 ultralite rocker setup, right?
Old 05-19-2018, 05:44 PM
Brandon619
Brandon619's Avatar
No, 6645
Old 05-20-2018, 12:33 AM
xBoostx
xBoostx's Avatar
T&D machine makes the shaft mount roller rocker arms for the Trick flow 255 heads I have both can order several options from T&D like light weight where they cut a groove off across the center, those come with oil routed to the tip rollers which I decided against it plenty oil flying around no need for extra oil pressure bleed, mines are also adjustable.
T&D have a racers program only charge for service parts needed no service charge and quick turn around you pay for the ride.
To tfs 255 rocker suggestions??
Quick Reply: tfs 255 rocker suggestions??
