Headed to the track tonight...let's play guess the ET!
St. Jude Donor '12-'13
Just as a frame of reference, this was the cars best pass before I put the new heads on it
Category : LS2 Internal Modifications
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post #_____:Time slip posted below
3. The complete the details of your pass using this template in your post:
4. Year Corvette: 2006
5. Type of Trans: A6
6. Type of Suspension: Stock Z51
7. Stock Performance : None
8. Tires utilized: MT 275/40/17 on C5 front wagon wheels, 17" Race Star wheels on 185/55/17 up front.
9. Modifications if any: Spinmonster cam, untouched 243 heads, Ported FAST 102, stock 90mm TB, Stock A6 w/Yank 3600 ss conv, 1 3/4" Kooks LTH with cats, Corsa Sport, Vararam, drag radials, UDP, Tune.
10. Dyno numbers if you have them 439 RWHP 397 torque.
11. As much info you may want to add about the run, launch techniques, tire air pressure 16 PSI
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track: Byron Dragaway
___ Date of the pass & weather conditions: 11/2/13: 145 DA
___ 60'............. 1.548
___ 330'........... 4.550
___ 660'........... 7.067
___ 660’ mph.... 97.44
___ 1000'......... 9.232
___ 1320'......... 11.062
___ 1320’..........122.05
Received 2,060 Likes
Finally into the 10's!
8. Tires utilized: MT 275/40/17 on C5 front wagon wheels @ 20 PSI, 17" Race Star wheels on 185/55/17 up front @ 40PSI.
9. Modifications if any: Spinmonster cam, PRC Stage 2.5 Heads, Ported FAST 102, stock 90mm TB, Stock A6 w/Yank 3600 ss conv, 1 3/4" Kooks LTH with cats, Corsa Sport, Vararam, drag radials, UDP, Tune.
10. Dyno numbers if you have them 455 RWHP 408 torque.
11. As much info you may want to add about the run, launch techniques, tire air pressure 20 PSI
___ Name of the Track: Great Lakes Dragway
___ Date of the pass & weather conditions: 9/11/14: -169 DA
___ 60'............. 1.549
___ 330'........... 4.535
___ 660'........... 7.017
___ 660’ mph.... 99.67
___ 1000'......... 9.153
___ 1320'......... 10.951
___ 1320’..........125.20
Congrats on the 10.
It's a great relief when you get the first one. Now you can have fun and do it again without the pressure.
