Install a long spolier on 2006 coupe
I saw a clip on forum on how to install a long spolier on vettes of 2005 to 2013 anybody have that clip
Or just changing out the base spoiler to a higher profile Z06 shorter rear spoiler.
If you are asking about the front spiltter, side skirts and rear spoilers, then would need to know what brand/type you are planning to install since each time kinds of mounts differently.
Note, if you are adding all this for added down force, then look into the Katech complete aero system. Its been wind tunnel tested/ ballanced for equal down force from to back.
To add, the stock Vet has lift at speeds, so if you just going to add a ZR-1 type rear spoilers, it going to upset the balances of the car at high speeds (read front end is going to lift, while the back end is going to have down force instead. For this alone (read performance), might want to go with a z06 front splitter and z06 rear spoiler, or if you want to go with a stock ZR-1 rear spoiler, then install the stock ZR-1 front splitter and side skirts to down force balance the car for high speeds.
