LS9 or LS7 cam swap???
Old 07-20-2014, 04:33 AM
BlackFya
BlackFya's Avatar
Default LS9 or LS7 cam swap???
Has anyone done this to their LS3? I am looking to get a bump in power but still need to pass smog/emissions. Any feedback would be greatly appreciated?
Old 07-20-2014, 09:52 AM
Wallacefl
Wallacefl's Avatar
...LS9 was done on the Camaro forum= 13 rwhp..LS7 would be about the same. You probably could get about 10-12 rwhp from the SLP 1.85 rocker arms instead of changing/doing the cam but would need to change the valve springs.
Old 07-20-2014, 12:51 PM
Pitufina
Pitufina's Avatar
Too much work for minimal return. If you have to have a cam, then go custom. With a custom you can have the cake and eat it too.
Btw, you have to change the cam sprocket too since both are 3 bolt type unlike the 1 bolt in the ls3.
Old 07-20-2014, 06:11 PM
Thunder8
Thunder8's Avatar
Not even worth the hassle and cost for minimal gains! Go with a custom grind, get 40HP, maybe get the heads ported and polished while you're at it and get another 15-20 HP. Be sure to do the dual rocker springs while your swapping out the cam.
Old 07-21-2014, 10:46 AM
Wallacefl
Wallacefl's Avatar
if you are going to do the LS9 cam I would look into GMPP 19300535..probably not 40 RWHP but with a tune 30 seems possible. I have been looking at this "combo" also.
Old 07-21-2014, 10:59 AM
Speedforhire
Speedforhire's Avatar
The GM Hot Cam is rated at 480+ flywheel HP...........a substantial gain, on the LS3, with just a drop in and retune.
My thoughts are "GO BIG or GO HOME". It's not worth the time and logistics.
Old 07-21-2014, 04:29 PM
n8dogg
Support Corvetteforum!
n8dogg's Avatar
How strict are the emissions tests in NC?
Old 07-21-2014, 06:37 PM
old motorhead
old motorhead's Avatar
Received 1,336 Likes on 945 Posts
That combo is an LS7 cam with CNC ported LS3 heads. For all of that, you get a whoppin' 40 hp increase? Get in touch with Pat G and get him to spec you a cam that will pass emissions. He's done a jillion of them.
To LS9 or LS7 cam swap???
Quick Reply: LS9 or LS7 cam swap???
