Service active handling ABS light
On my C6 2005 Service active handling system light came on Traction control works fine and brakes worked five I'm thinking it's some kind of bug can anybody tell me what the problem is and what I can do
Don't want to scare you but you need to take this as a potentially serious safety problem.
Since we don't know anything about your car and we don't know what you know about your car's history, I suggest you acquaint yourself with these 2 discussions (from the Stickies at the top of this Forum) then go to your dealer and get a history printout on your car to find out what has or has not been done. Then you can make informed inquiries, ask questions here and make appropriate decisions.
http://forums.corvetteforum.com/c6-t...er-action.html
http://forums.corvetteforum.com/c6-t...-recalled.html
Received 8,930 Likes
Get the codes read by somebody who has a scanner that can read ABS codes and report them back here. The Service Message is displayed when there is a code affecting that particular function. It sounds like you have a solid message that doesn't come and go. AH is totally inactive until the message disappears so you don't have to worry about a safety issue while it is displayed other than not having AH.
Failures with the steering sensor can cause AH to shut down while keeping ABS and TC active. I do this when I take my car to the track. I pull the connector to the steering sensor so the system can't use AH to slow my car to 55 mph when I use tires without tire pressure sensors.
Bill
It used to come and go now it is on Traction control seems to work fine And ABS brakes seem to work fine also But that is a great idea to Get to codes and post him on a form Will a place like AutoZone Have a scanner
Without OBD codes, its all a WAG, Had that DIC msg on my Escalade, checked code and it reported Throttle Position Indicator. Got an AC Delco replacement from Amazon and it was just a half hour job I did in my driveway. But you need the codes. Buy a reader from AZ. They aren't expensive.
