Oil change
Oil change
I bought my first Corvette, pick it up next week. I want to change the oil ( it looks good, but I am **** ). I have floor jack & stands. What do you use to raise your car & where do you lift it at?
For oil changes I raise the car one side at a time with a jack at the front frame lifting point near the front of the door (with a hockey puck as a pad between the jack and frame), and set it on some Rhino Ramps.
It can be done without getting under the car by removing the wheel.
I refer RaceRamps since the ramp can be easily removed once the car is in the air. Very fast and safe.
Some info on jack & stands placement.
http://www.bugmanweb.com/c6/jack.html
