Cam questions (not the usual)
Old 05-23-2014, 10:21 PM
mfquinn
mfquinn's Avatar
Default Cam questions (not the usual)
Deciding what cam to get is confusing enough but I have a few other questions. I'm at 111,000 miles with never a mechanical problem. Loads of track days and 1/4 mile passes. My radiator needs to be replaced so I figure time to do a cam swap. I have a 2008 LS3 with BB long tubes and a Vararam. Questions:
Due to the high mileage, what else should I do/replace? Engine will be pulled so nows the time to do it
I believe the 2008 LS3 cam is a single bolt. Should I convert to a three bolt? This is confusing
Any other words of wisdom?
Old 05-23-2014, 11:56 PM
shawnaj7731
shawnaj7731's Avatar
lifters, cam chain,valvetrain.
Old 05-24-2014, 07:01 AM
D.Guerra
D.Guerra's Avatar
Water pump, oil pump, hoses, maybe DoD delete if yours is equipped is what I got to share. First three for sure.
Old 05-24-2014, 08:34 AM
Kip Fabre
Kip Fabre's Avatar
Go with the 3 bolt for sure. No DOD.
To Cam questions (not the usual)
Quick Reply: Cam questions (not the usual)
