Valve spring question?
Old 05-03-2014, 02:52 PM
Realfast86
Realfast86's Avatar
Default Valve spring question?
Getting my Mast 305 heads setup soon but wondering what the best spring would be I'm gettin Manley nextek's and have two options=
.660" 1.295" .676" 155 @ 1.810
405 @ 1.150 379lb rate 1.100" coil bind
OR
.700" 1.340" .726" 170 @ 1.810
446 @ 1.110 394lb rate 1.050 coil bind
These are for a FI build with hollow SS int/Inconel ext. valves, 3/8" push rods, shaft mounted rockers and cam lift around .640 with Morel high rpm linkbar's plan to spin to around 7-7200rpm which one will work best with the heavier valve train
Old 05-04-2014, 02:59 PM
Realfast86
Realfast86's Avatar
Ttt!!!
Old 05-04-2014, 05:58 PM
glenB
glenB's Avatar
St. Jude Donor '08-'09 & '12, '14
Since you're going forced induction, I would use the heavier of the two springs.
To Valve spring question?
Quick Reply: Valve spring question?
