Question - New pads/rotors.. poor braking
Sigh.
Tried changing pads and rotors last week.
Ordered Z51 rotors from Ecklers, and Z51 pads from GM Parts House...
Had the dealer do a full flush/bleed w/ Tech2. I'd planned to do this anyway. It'd been over a year since the last flush. Peddle got softer and more travel, had to go back and have them redo the flush/bleed. Seems better now...
Have gone through the bedding process.. Rear rotors still don't look like they're bedding properly.. It's like the rear pads aren't making full contact...
Even after two bedding attempts, car just doesn't stop properly. I can burry my foot into the floorboard w/o the ABS even thinking about engaging.
(No not trying to panic stop engage the ABS right after any attempts at bedding, this is hard braking the next day)
Honestly not sure what to even try next.
Extremely frustrated.
Any thoughts/suggestions? Anything I should look for that could be causing braking issues w/ new pads and rotors?
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I don't have answers for you, but maybe I can ask some questions for next person. Did you have the dealer do the bleed/new fluid first, or after the brake pad/rotor installation? What kind of miles and type of driving on your '08?
I can't be certain but if ABS isn't activating, seems like there isn't enough line pressure which sometimes means air in system or brake master cylinder (or proportioning valve but that may be electronic/computer controlled). I have heard of the last-mentioned needing to be replaced which is strange (to me) since it's usually a long-lasting item.
You replaced the pads and rotors because they looked worn or weren't giving good stopping power? It may be the last time it was bled, it wasn't done sufficiently either. Someone else will chime in I'm sure.
Good luck with it. Do a search on brakes, bleeding, master cyl., etc. in advanced search for C6 Gen and Tech. May uncover your reason/issue and solution.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
The Tech II bleed can un-cover some issues in the ABS box or possibly a valve is stuck...
However.
I am still a big believer in manual two person bleeding because you can see what is going on with it, and see if there is any air coming through the lines, or maybe there is a leak at a line, or a crush washer that you wouldn't see using a machine or one person bleed system.
Since you still have the stock calipers a few things I would look at.
I know you said you bedded them in, but you might try taking the pads out and sanding them lightly as well as the rotors and then washing them down.
Being that you are not getting into ABS tells me a couple things or a possibility of a few things.
However.
- Are the calipers free to move on the sliders?
- do you see any leaking at the pistons?
- Did you wash the rotors of any grease or oil when they went on for the first time?
- Check the PN on the pads. If it isn't a Z51 pad, and might be a ceramic pad that could be one issue
- if the pedal is soft you might have air in the system from a leaking line, fitting, or caliper seal. Could also be a hurt soft line too
- Do you see any error codes for Traction control, Active Handling, or ABS?
Thanks - follow-up
I took some time to re-bed the brakes...
Final bed-in procedure...
1. 10 35mph decelerations
2. 5 45mph decelerations
3. a few 60-30 decelerations
Rear brakes *finally* looked like they were taking material/bedding-in...
Next day tried some hard braking and was able to get the ABS to activate..
Recent AutoX went well.
Peddle still seems a touch longer than before.. Wondering if the Tech2 has uncovered some additional issue yet to become clear?
Flush after new pads/rotors, 50k, daily driver + monthly autocross.
Pads were worn, rotors had large lip on the edge from wear.. preventative maint. in advance for additional auto crossing.
However.
However.
- Are the calipers free to move on the sliders? Not clear what you mean
- do you see any leaking at the pistons? No visible leaks
- Did you wash the rotors of any grease or oil when they went on for the first time? Used brake cleaner during assembly
- Check the PN on the pads. If it isn't a Z51 pad, and might be a ceramic pad that could be one issue Pads seem to be correct
- if the pedal is soft you might have air in the system from a leaking line, fitting, or caliper seal. Could also be a hurt soft line too Not soft, just seems long.. which seems odd to me w/ new thicker pads?
- Do you see any error codes for Traction control, Active Handling, or ABS? No codes
That's easy, stand on the brakes - hard. You'll feel the abs kick in by a pulsation in the pedal and you'll feel/hear the chatter coming from the brakes and tires. Also, the tires won't lock up on you as evidenced by your ability to steer the car with the brakes on hard.
Received 8,924 Likes
Bill
I'm not as familiar with these fancy new braking systems, but if I had a mushy pedal and I was confident that all air had been removed (and no fluid leaks), I would be checking the master cylinder. You could always go with steel brake lines, but the pedal should not be soft with the stock brake lines, either.
