Horse power numbers
Horse power numbers
Hey guys. Ok I got my package together. I want to know how many horsepower I can expect from the mods below. The car is an 06 ls2 with the six speed manual. The mods are as follows. Stage 2 ported ls3 heads, all new valve train from comp cam, set of kooks 1 3/4 inch headers with offroad x pipe, corsa sport exhaust, and the cam is 54-469-11 from comp cam. Please guys any estimates would be appreciated.
450-460rwhp. I'm basically running same mods on my LS2, haven't done heads yet, 428rwhp. Consider a Fast 102 intake. They really wake up the LS2. That's next on my list, then heads. Should get me close to 500.
I dont think he can run the fast, he has LS3 heads, with the stage 2 heads in the 490 heads ported
What intake could he run? Stock? Ported stock? But if he can't run a Fast 102 for an LS2 w/LS3 heads can he run the stock LS2 intake w/LS3 heads? Seems if all is well running stock LS2 intake w/LS3 heads you should be able to run LS2 Fast? Idk, I'm learning something here.
I have been planning all of this for a year now and "typically" on the low side 440rwhp and on the high side 460+/- with TQ in the @ 425 range.
as stated you have to run a LS3 intake, no question about it, you should be around 460 to 475 range and your torque should be around 420 to 440 rwtq not sure the specs on the cam with out looking but that these numbers will be real close. Don't waste your money on a fast you will have a ls3 intake which is decent.
LS3 intake and fuel rails or even better, a Fast 102 if your heads can peak flow at the right cam point.
You need to flow the heads to see what the peak CFM point is, then you know how much lift you need.
Ok so besides the stuff I mentioned above what else will I need to make this work for sure. My tuner is a 12 hour drive plus an 8 hour ferry ride. When I get there I want everything to be right I don't want to get there and be missing something. So I need the ls3 intake that's no problem I can pick one up pretty cheap. Do I bed the fuel rails or not??? Is there anything else I'm missing guys. Please any help here will be greatly appreciated I don't want to miss anything. Thanks.
I'm sorry if i mislead you, the rails are the same but I believe the Fuel injector height difference is the real issue.
You can use spacers I'm pretty sure
http://hinsonsupercars.com/p-1125-fa...r-kit-ls3.aspx
Also, I would replace the Crank Damper/ harmonic Balancer, timing chain too
Navigator
I would like to slightly wake up my 06 ls2 so far I have changed the h pipe to xpipe magnaflo muffler installing vara ram snake charmer don't want to bother heads or cam wondering if there a better cool air or if snake charmer the best love stock performance just want to optimize stock performance thanks for advice
I added ported Intake and TB, Headers, catted X-pipe, catback, Honker CAI and a mail order tuner and the core woke up substantially, probably from 335 or so RWHP to 390RWHP, maybe more with a dyno tune. the car halls now.
Navigator
cleanup stock performance on ls2
I just want to optimize stock performancealready did exhaust magnaflo x pipe vara ram snake charmer mostly a daily driver don't want to do heads or cam just minor events love stok performance just wantto get all out of it I can get without going radical
Hey guys thanks for the help. With this cam should it be a nice choppy, thumping sound??? That's what I really want with some nice power to back up the sound!!!
Hey bud. Just wondering how you like the cam. Is it nice and loud. I want a nice choppy thumping cam. It should sound pretty good coming through the kooks hey???
