Stock 05 LS2 C6 MN6: Best 1/4 mile techniques?
I'm new to the C6 and I want to go to the drag strip this weekend to baseline my car. Can someone tell me the best launch and shift techniques to lay down some low ETs?
My car is basically stock. It has a Borla cat back muffler set up and a CAI with factory Eagle F1 supercar run flat tires. I don't think the car has ever received a tune.
What rpm should I launch at and what rpm should I make my shifts?
Should traction control and stability control be on or should I be in Competitive Driving mode?
Recommendations on front and rear tire pressures?
I'd appreciate all they help I can get.
I am aware that track officials might not let me pass inspection due to the removable roof, but that is a different issue for a different thread.
Thanks.
Thanks.
Don't do the burn out and if you do stop if you have wheel hop. You'll break an axle. Learn your car for launch to get the least to no wheel spin at take off. Mine is set up to shift at exactly 6500 thanks to the tune. If you go to slicks or sticky tires on those axles they'll break.
Any other advise guys? You don't want my Vette to get beat by a mustang or a challenger, do you?
Thanks for the advice DG. If this car has wheel hop and it can't be resolved inexpensively, I'll sell the car bcs that would be a huge disappointment. I've never heard of a Vette having wheel hop. It's also hard to believe GM would make an axle that couldn't handle the stock torque but I'll play it safe on my launch.
Unfortunately you have an '05, the weakest of the C6 rears, a 6sp manual, and no experience launching these cars. That's a recipe for a short and expensive night at the track. If you're just going for fun and to learn, launch off idle and slowly start raising the launch RPMs on each consecutive pass until you start to get comfortable. Then play around with launch RPMs until you start seeing a reduction in ET. But if you get even the slightest amount of wheel hop, even after you launch, (the 1-2 shift) get out of it. Let the Mustangs and Challengers win. It's not worth the tow ride home.
Good luck and enjoy.
Received 1,193 Likes
St. Jude Donor '15
Don't take all this the wrong way. It's not as if you're rear is suddenly going to just explode because you get on it a little hard. You just have to be aware of it's weaknesses. Overzealousness and inexperience is always a recipe for disaster. If you want to play at the track, do it with no ego. Learn the car so you can have many years and miles of enjoyment. Then as you start to improve, you can begin modding the things that are holding you back. Dif, tires, HP, etc. The C6 is a great car, you just have to understand it's limitations along with your own.
I remember my LS1 Z28 had lots of wheel hop until I ground that bitch to the pavement with suspension parts. It cost a few bills but I ended up upgrading gear set too so it worked out I guess. The 17x11s and 315/35/17s didn't help either. But at 450/460 at the fly, I expected to break a few parts.
