cam install...now airbag interemittent + dyno numbers
Old 04-16-2014, 05:49 PM
Hypforlife32
Hypforlife32's Avatar
Default cam install...now airbag interemittent + dyno numbers
whats up guys, i did a cam install over the weekend. and now have an intermittent airbag light. From a little research it seems that it is most likely the clock spring but if it was the clock spring wouldnt it be on all the time?? Mine only comes on and off when i move the wheel? If you hold the wheel straight and cruise for 20/30 sec it goes off but as soon as you make a turn or anything it kicks right back on again...Is it the clock spring or is something else off??
THanks in advance.
Prior to cam install i made 386 whp and 390tq
mods:vararam, kooks 1 7/8 headers, no cats. corsa sports.
with cam, under drive pulley, and ported tb i made
449 whp, and 407tq.
Old 04-17-2014, 03:51 PM
Hypforlife32
not one person has any idea?
Old 04-17-2014, 05:29 PM
DEE_Vette
DEE_Vette's Avatar
You need to find someone with a Scanner and find out what code is being set... Once you have the code you will know which direction to look... Clockspring would be high on my list if you removed the rack & pinion and some how turn the wheel with it disconnected...
Old 04-17-2014, 05:50 PM
brewcitygymratt
brewcitygymratt's Avatar
St. Jude Donor '13
sorry no help on the airbag light issue but wanted to say nice cam/pulley hp gain!
To cam install...now airbag interemittent + dyno numbers
Quick Reply: cam install...now airbag interemittent + dyno numbers
