Fuel cap door will not stay closed?
I haven't tried fixing it yet but wanted to see if anyone else has experienced the same issue as I.
As I was driving one afternoon I noticed my fuel cap door was opened. Thinking my knee possibly hit the button. So I closed it , then a few miles and bumps later it opened again. Kept doing that until it got to the point that it will not stay closed at all now ? What would you guys recommend I look into first to fix this minor issue? Thx
Happened to me a while back... info in this thread may help you:
http://forums.corvetteforum.com/c6-c...d-autopsy.html
In my case, the spring inside the actuator had to be replaced. Pulled the left rear wheel and fender liner, pulled the actuator out, and replaced with a spring I found at Home Depot. I just bought one of those packages of assorted springs and one of them worked just fine.
