Corvette is dead! Help!
Old 03-25-2014, 05:34 PM
exracer28
exracer28's Avatar
Try asking for someone with a tech II to check it out. The remote control receiver may have died and does not read the FOB. Is the theft light on?
Old 03-25-2014, 05:51 PM
ezcarbo
4th Gear
Support Corvetteforum!
ezcarbo's Avatar
Default Fuse Box
Originally Posted by 615C6
Battery passed load test.
Make sure your fuse box is secured, tighten down all 4 post .
you may have a bad ground at the fuse box.
I have a 2005 vette and my fuse box became loose and ungrounded, my would not start.
hope this helps.
enzo
Old 03-25-2014, 09:21 PM
615C6
615C6's Avatar
Thanks guys. BCM didn't make it here yet. Should be in tomorrow im guessing. No security light or anything. Instrument cluster is completely dead. Only thing that works on the car is the under hood light and headlight and taillights when I switch them to on. I spoke with a tech that has a tech2 scan tool and I will get him to re program the BCM once I install it. Fuse box is tight and all grounds are good and clean. The starter wire is good. Wiring harness is good also. No blown fuses or relays. New key fob battery and car battery. Hopefully once I install the new BCM at least my cluster should come back and ask for key FOB.
Old 03-26-2014, 02:43 PM
615C6
615C6's Avatar
Installed new BCM and no change. The 4 post that secure the fuse box are snug. Is that the post that ground the fuse box? If so im not getting continuity to ground on either one of those 4 post.
Old 03-26-2014, 04:23 PM
615C6
615C6's Avatar
Just realized when I connect my battery post to the battery I can hear something wine in my dash. Almost like the sound of a fuel pump priming. My best guess is nav/radio. My power seats will work but my door locks and windows don't. Also my emergency flashers work but wont show in my cluster because my cluster is still dead. With my battery connected I checked for voltage at the PCM 15A fuse on BCM and im not getting voltage there. Not sure if I should be getting it there and if so when? I am getting battery voltage to my BCM from the red with black stripe wire and also the red with white stripe.
Old 03-27-2014, 05:03 AM
DillingerRadio
DillingerRadio's Avatar
St. Jude Donor '14
Your mention of the board under the passenger side reminded me of this post.. I would check it out:
http://forums.corvetteforum.com/c6-c...g-gremlin.html
Old 03-27-2014, 06:03 PM
615C6
615C6's Avatar
Did the BCM wiggle test with no change. I double checked my wiring harness and did find this. Which I thought for sure would fix my problem. I soldered and heat shrink these two wires but still nothing. Does anyone know if a bad key fob or security system would cause these symptoms? Any last resorts before I have to tow this to the dealership?
Old 04-23-2014, 03:58 PM
615C6
615C6's Avatar
Wanted to give y'all an update. The car is at the dealership getting checked out. The advisor called me letting me know they can't communicate with any of the modules. There going to check each module.
Old 04-23-2014, 04:10 PM
DillingerRadio
St. Jude Donor '14
Keep us updated, I'm actually really interested now in finding out what was up with it.
Old 04-24-2014, 03:19 PM
SOFLO
SOFLO's Avatar
I hate the dreaded "can't communicate with module" thing from the advisor... just had my TCM go out and had it replaced. Car is great now though
Good luck!!
Old 04-24-2014, 03:37 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Old 04-24-2014, 03:59 PM
615C6
615C6's Avatar
Yeah I'm hope it's just the BCM. I'll def keep y'all updated.
Old 04-25-2014, 06:19 PM
  #33
Chevy Cust Svc
Chevy Cust Svc's Avatar
Hey there,
I’m sorry that I did not see this earlier, but we’re around as well to answer any questions you may have. Let me know how it goes. Have a good day!
Jennie R.
Chevrolet Customer Care
Old 04-25-2014, 07:13 PM
  #34
Z06_N_SD
Z06_N_SD's Avatar
Having a similar issue. Definitely interested as to what is it.
Old 05-01-2014, 07:54 PM
  #35
blackbeast1
7th Gear
blackbeast1's Avatar
end of the story, is it running?
Old 05-02-2014, 12:38 AM
  #36
615C6
615C6's Avatar
No. Dealer still hasn't found the problem.
Old 05-12-2014, 03:26 PM
  #37
silverGS
silverGS's Avatar
anyupdates?
To Corvette is dead! Help!
Old 05-12-2014, 08:34 PM
  #38
615C6
615C6's Avatar
Originally Posted by silverGS
anyupdates?
Went to the dealer today and all the service advisor could tell me was they had nothing for me yet. All they tell me is they cant communicate with any of my modules and need to test each module. Its been 4wks! starting to get ridiculous. GM service is awful.
Old 05-20-2014, 08:25 AM
  #39
silverGS
silverGS's Avatar
mines did the same thing and my car was a bad pcm have they checked your pcm 4 weeks with no car and they still dont know what is going on.
Old 05-20-2014, 02:41 PM
  #40
615C6
615C6's Avatar
They already tried a the new BCM and still couldn't communicate. This Saturday would be 6 weeks they had the car. I know the RCDLR sends a signal to the BCM then the BCM sends a signal the PCM. Its either of these 3 modules they just havnt been working on it. I talked to the tech yesterday and they told me they only work on it 1-2hrs here and there. Then I told them my opinion on that and how its been 5 weeks. Also said ill send it else where if they cant handle it or get forward progress on the car. So your car was acting the same way as mine? How did your problem start?
Quick Reply: Corvette is dead! Help!
