2008 Corvette Fan Sensor Location?
Old 03-12-2014, 12:33 PM
BowtieBilly1121
BowtieBilly1121's Avatar
Default 2008 Corvette Fan Sensor Location?
On my 2008 Corvette with the LS3 engine where is the fan sensor location(the one that turns on the electric fan motor not the one to the gauge)? Where is the fan relay located? The electric cooling fan on radiator is not coming on at any temp, it caught me in traffic and got up to 250 degrees. When I got it home it was between 230 & 240 degrees and time I got the hood open with it running it was over 250 degrees and the fan was not running then I shut it off instantly. I can put 12 volts directly to the fan and it works. By it not coming on at any temperature I suspect it is the fan temperature sensor or fan relay. Thanks,
Old 03-12-2014, 12:38 PM
EVRose
EVRose's Avatar
There is a connector mounted to the side of the fan half way down on the passenger side. Pull it apart and check for burned wires inside each half. Its a common problem on these cars. You can bypass that connector and be good to go.
Old 03-12-2014, 02:42 PM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
It's a 3 wire connector. If it appears to the naked eye to be good, then check for continuity on each side of the connector. If you find a bad connection, you can either bypass the connector or buy a replacement. Unfortunately, the GM replacements are worse than the OEM and it's likely to happen again.
Experience speaking here and currently using bypasses.
Old 03-12-2014, 02:55 PM
victorf
victorf's Avatar
Don't pull - need unlocking first.
I am posting for post count - need to build up my ego!
Old 03-12-2014, 03:40 PM
BowtieBilly1121
I looked at the outside & wires going in & out and they all looked good,will go back and take it apart and check the inside.Hopefully this will solve my problem.I will let everyone know.Thanks
Old 03-12-2014, 04:11 PM
EVRose
EVRose's Avatar
And I guess I should go back and delete mine now huh.
Old 03-12-2014, 08:00 PM
BowtieBilly1121
I'd like to thank everyone for your valuable help!! On the outside the three prong connector looked new, but on the inside, you could tell it had melted. I by-passed it & it is working fine now. Once again, THANKS, Billy
Old 03-12-2014, 09:28 PM
victorf
victorf's Avatar
Right on!
As mentioned, continuity check will separates good and the bad.
To 2008 Corvette Fan Sensor Location?
Quick Reply: 2008 Corvette Fan Sensor Location?
