MGW shifter....type of lube?
Old 02-28-2014, 07:41 PM
jovette
jovette's Avatar
Default MGW shifter....type of lube?
I just purchased a slightly used MGW shifter, and I got everything that came in the new kit, with the exception of the lube for the shifter. Anyone know what type of lube I should use or where I could purchase the proper lubricant?
I do have NAPA Silicone lubricant in a blue tube, which I use for lots of uses, including brake pad backing, but am not sure if it's the proper lubricant for the shifter.
Thanks!
Old 02-28-2014, 07:51 PM
DillingerRadio
DillingerRadio's Avatar
St. Jude Donor '14
That's a good question- and one you may very well see George from MGW answer. I don't know offhand, as I have what came on the shifter in there.
Old 02-28-2014, 07:53 PM
timd38
timd38's Avatar
Mine came with gasket sealer, but no grease, so I thought!
Old 02-28-2014, 09:43 PM
sevinn
Support Corvetteforum!
sevinn's Avatar
St. Jude Donor '14, '16
This is what mine came with.
Old 02-28-2014, 11:34 PM
Zoxxo
Zoxxo's Avatar
Ditto.
Z//
Old 03-01-2014, 02:23 PM
jovette
jovette's Avatar
Thanks for the response and the pic! A guy @ the local corvette and hot rod shop just today told me that they simply use white lithium grease, but it seems to me that a synthetic would hold up to the high temps better.
To MGW shifter....type of lube?
Quick Reply: MGW shifter....type of lube?
