Question about new MGW shifter
I just received a new MGW short shifter and lower box. I hope to have it installed within the next week or two. However I do have a question about it which I'm sure George can answer but wanted to ask here in case someone already knew the answer or if someone was looking for the answer.
The shifter everyone pictures and is still shown on the MGW website is what I expected to receive:
What I received, however is pretty different in terms of handle attachment and location:
Notice how the handle attach point is now way out at the 1 o'clock position and not at the center? I'm not familiar with where the stock handle attaches to the stock shifter but this is definitely different than what I expected for the MGW.
Is this going to end up feeling significantly different than where I place my hand on the stock shifter now? Is the shift motion going to be seriously affected in terms of angles for all 1-2, 3-4, and 5-6 shifts? Maybe? Maybe not?
I'm surprised that the gold block is not rotated "in-line" with the fore-aft axis and is at that 1 o'clock angle. The hex bolts showing apparently hold the block onto the lever which as you can kind of see is a solid 0.5 x 1.0 block (pretty beefy) and does not seem to be able to rotate or be repositioned.
Maybe this is an even newer design to help with more sound issues?
Anyone have any info on this?
Thanks for any help you can provide. I looked but did not find any info on "new" MGW shifters or angled billet blocks or the offset handle. I certainly could not find any pictures of this particular shifter!
Thanks!
Kevin
Thanks!
Kevin
I would have faith that if MGW updated the shifter again, it is bound to be as good as the one I have..........BUT I don't know how it could be better. I love the one I have. Very smooth and crisp shifts.
The shifter everyone pictures and is still shown on the MGW website is what I expected to receive...
What I received, however is pretty different in terms of handle attachment and location...
...this is definitely different than what I expected for the MGW.
If George doesn't chime in here you can always phone him.
George knows what he's doing. Install it. Enjoy.
Z//
With the new design, the handle and ball are (with logo towards driver) a bit farther forward and to the right now. If the shifter is actually symmetrical and *can* be installed with logo to the right, that would put the handle/ball farther aft and to the left. About 1.5 inches fore/aft and left/right but a full 2 inches diagonally (thank you Pythagoras).
If you just look at your hand, I guess 2 inches is really nothing in the grand scheme of things since the shift ball is close to that diameter anyway and the difference in location is probably insignificant in use.
So I'll install it and see how it goes. Should be fine.
Thanks for the input.
Kevin
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
just for peace of mind, I'd ask the question of George. that's quite different from the one pictured on this thread that was bought six months ago. from everything I've read, George is always tweaking and improving things. I say, ask the question. and please tell us what the answer is.
note: there may be a difference tho since Op's car is an '05 T56 and NC's is a '10 TR6060.
Z//
St. Jude Donor '14
I ordered that same shifter- it's arrived but I'm stationed overseas right now. I'll see if I can't get my dad to send me a shot of what it looks like out of box so I can confirm whether or not I got the updated one you received or the one shown in the photo.
I received mine in January. It matched the website. Since MGW sells shifters for Ford and Mopar I would verify that you weren't sent the wrong shifter just to be sure.
I agree with those who say to call George first. The last thing you want is to perform "open - heart surgery" on your baby only to discover you were sent the wrong shifter. Even though I've performed said surgery more than once and could now probably do it blindfolded, I'd hate to have done it needlessly.
One simple phone call. I'd do it.
P.S. If it's a new design, please tell us all about it!
Former Vendor
hey guys,
the handle is actually only offset 5/8" left to right and 3/4" front to back so not near 1.50 or 2 inches from the centerline. It just looks that way if you measure from the back of the gold handle which is NOT the centerline of the shifter.
we did it for 2 reasons which will not affect the shifting at all...
1. we USE to have an offset bracket and then when we switched to the center mount we had a lot of feedback from people wishing we still had a slight offset because some people have short arms and long legs and some people have short legs and long arms so this new design actually lets you get the shifter a little closer or a good bit farther away just by swapping it mirrored.
2. the new c7 boots are a bit stiffer and less material than the c5 and c6 and the old design was a little bulky. it worked but this design is a lot less bulky in the boot area so it just works a little better.
Hope this clears things up.
Regards
George
Regards
George
