Oil dipstick install
Old 01-04-2014, 04:49 PM
joshz06
joshz06's Avatar
Default Oil dipstick install
Installed ls7 manifolds on my 05 Corvette and have been unable to reinstall the oil dipstick what am I doing wrong?
Old 01-05-2014, 01:58 AM
berk4422
berk4422's Avatar
You need a second set of hands to guide from above the engine bay.
Had to have my wife spend 30 seconds in the garage on this... After I spent 10 minutes unsuccessfully trying to re install on my own.
Old 01-05-2014, 03:13 AM
glenB
glenB's Avatar
St. Jude Donor '08-'09 & '12, '14
Put all the bolts in the manifold but leave the manifold loose.
Insert the tube into the pan, you will probably have to wiggle/bend/finesse the tube a bit to get it to fit.
If I remember it has to be bent forward slightly to fit, but it will go in. Once you have the tube installed in the pan tighten down the manifold and then finesse the tube to put the bolt in.
It's a one person job ......
To Oil dipstick install
Quick Reply: Oil dipstick install
