Exhaust manifold question?
If you have the M6 then it is a true bolt on swap you can install the entire Z06 exhaust from exhaust manifolds to the mufflers. The A4 will take some instant modifications to fit
Nope, We installed it on my 2005 A4 and my son's 07 m6
here is a link of an installation on the A6 http://forums.corvetteforum.com/c6-t...tall-help.html
If you do a search you will find many threads regarding installing the exhaust on the A6.
The problem areas are:
1.) spreading the mid pipe to fit around the trans
2.) fitting the 3" inch pipes around the trans
3.) Keeping the heat away from the various lines & etc.
