C6 Keyless entry module and wiring diagram needed.
Hey guys, I'm new to this site. I've tried to do a search for what I am looking for, but I haven't been able to find it. I'm needing a schematic or diagram or something telling me what wire I can tap into for a remote start input wire from the factory keyless remote. That is the only wire I need to finish this up.
If anyone knows a better way to do this, then please let me know. In a vehicle that has a door lock or unlock motor I can usually tap into that wire for my input pulse to activate/deactivate the remote start with the factory keyless remote. But with these cars, I can't do that.
Thank you in advance for any help.
What exactly are you looking for? Installing a remote start? starter make/model?
You're going to a very hard time getting an 'output' from the car. The whole system is CanBus data.
Thank you very much for your reply. Yes,I already have everything wired and working. I just need a negative pulse for my remote start input to start or shut off. I'm going to check out the keyless entry module when the unlock button is pushed, it signals something in the door, that is the wire that I'll want to tap into. I would think. I hope I make sense.
