ran over a parking lot concrete island, now have rear TPMS problems
So long story short I rounded a corner and discovered it wasn't where I wanted to go, did a 3 point-ish turn and didn't see a concrete island in the parking lot and up and over I went.
Scraped the frame/fiberglass in the front left behind the front tire and the rear right just in front of the rear right tire. There does not appear to be any other damage.
Now I'm getting a SERVICE TPMS message and both of the rear sensors are showing XX PSI.
Where is the signal for the TPMS picked up? Might I have snagged a wire somewhere? Where does the TPMS wiring run along the frame towards the rear of the car? I don't really see any wires vulnerable to getting snagged from scraping the bottom of the car.
This is a 2007 C6.
This is a 2007 C6.
This is a 2007 C6.
This is a 2007 C6.
Received 2,225 Likes
There are no wires. The TPMS uses a small round battery in each sensor which has about a 6 year or so life span. Some say they get more years - but 6 or so is an average. I would try to re-set the sensors first and if that doesn't work - well it's time to either replace the sensor or replace the battery in each sensor. The batteries are cheap but replacing the battery is a drawn out process which isn't hard but breaking the bead of the tire at home might be. I always have some old spare sensors ready for use which I have installed fresh batteries. I always take my car to Discount Tire for the re-learn which they do for free. In any case - it might just be a coincidence that your TPMS problem showed up when you ran over the concrete island. Good luck.
"Rebuild" is a misnomer. They change the tire sealing "O" ring and add a new nut. The unit is not "rebuildable".
All good info so far. Couple things you can try!
1. Deflate the tire let it sit 5 minutes then air it back up to what the placard says! That should reset the TPMS.
2. Have the tire shop scan the sensor to see if its still transmitting. If not then your sensor is bad. you need to replace.
Location: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
Let's use a little logic here.... The TPMS reciever (also the same reciever for your key fobs) is recieving the signal from the front tires.... So, it is working. Take the advice given in the previous posts and do a reset on all 4 tires. Go to discount tire and have them do it with their TPMS tool it will be quick and painless!!
Received 2,051 Likes
St. Jude Donor '13
By reseting I mean that it will recalibrate the TPMS. If the ID's are learned already then you don't need to do the relearn procedure. You just need to "wake" the tpms back up and the will fix the XX problem That is if the TPMS are still transmitting!
