High Torque Gear Reduction Starters! Very Cool!
Old 09-11-2013, 07:38 PM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default High Torque Gear Reduction Starters! Very Cool!
These new ProComp Pro Thunder High Torque Gear Reduction Starter Motors turn the engine over faster than any stock starters.
Producing between 30 - 40% more cranking power, these 100% Brand NEW starter motors also feature an offset design resulting in more clearance between the oil pan and the starter. These new Pro Thunder Starter is designed to crank over the highest compression engines on a hot day. They feature all new components beginning with a three horsepower motor, a reduction 4.4:1 gear set and a Anodized and Powder Coated assembly to protect and keep it looking good. The armature is balanced during assembly and is guided by two ball bearings for smooth engagement and thousands of starts The Pro Thunder High Torque Gear Reduction Starter also features a billet aluminum mounting block that can be positioned in different locations to help clear suspension parts, the oil pan and exhaust systems.
1 Year Warranty
If you have headers look at the measurement picture and see if you have enough clearance. We had one guy not have the nessesary clearance. He didn't know what brand the headers were. The starter DID clear our 1-7/8 Kooks Headers.
Because this starter takes 2 long bolts instead of one short and one long, we are supplying one long bolt with the starter to go with your exiting long bolt. We also rotate the starter for you to the same position that worked best on our engine. Also there is a small tab that is cast into the housing of the starter that touches the block. We are machining that off for you. It is one of those things that you wouldn't notice but it binds against the block when you tighten the bolts down. We found it because our engine was out when we installed it and had a good visual. We have been in contact with ProComp and they want to work with us to resolve it. Its a minor issue if you know its there and nothing you need to worry about because its taken care of when you receive your starter from us and in no way affects the warranty.
Added pictures below to answer some of the questions we are getting asked.
A quick word from SacCityCorvette.
We use one of these Pro Thunder high performance gear reduction starters in our high compression 444 cubic inch LS2 Stroker 02 Z06. It is awesome! It spins the engine over with ease! And you will love the way it sounds too! Its one of the notably best upgrades we have done! We highly recommend this starter for any LS series engine whether it is stock or a race engine.
Only $172.95
http://www.saccitycorvette.com/LSxStarter.html
We also carry OEM style starters. See below.
Here's what you get.
We have added the Pig Tail wire. It eliminates the need to modify your factory wire that screws on to the solenoid. Simply screw the pig tail and your factory wire together then use the shrink tube to insulate the connection. Then just plug the quick connect onto the new starter solenoid.
OEM style Starter $129.95
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 09-11-2013, 08:51 PM
EVRose
EVRose's Avatar
Nice looking part.
Old 09-19-2013, 06:38 PM
SacCityCorvette
Supporting Vendor
Thank EVRose!
Updated our post with more pictures and add more info in blue and red writing.
Christian
Old 09-19-2013, 09:07 PM
VET4LES
VET4LES's Avatar
I like it. If I ever need a starter this is the one I'll buy.
Old 09-20-2013, 09:36 AM
Gering
Tolero Apto Victum
Support Corvetteforum!
Gering's Avatar
Originally Posted by EVRose
Nice looking part.
Old 09-20-2013, 11:37 AM
EVRose
EVRose's Avatar
Originally Posted by Gering
It really is. Call me weird but if I needed a starter I'd certainly get this one and I'd probably put it on my coffee table for a while just to admire it before installing it on the car.
Old 09-20-2013, 11:59 AM
Gering
Tolero Apto Victum
Gering's Avatar
^^^ Me 2. It is sad that some of the best looking parts are located under the car and can only be seen when it is on a lift.
Old 09-20-2013, 07:48 PM
timd38
timd38's Avatar
Your PM box is full!
Old 09-20-2013, 08:08 PM
07MontRedcp
07MontRedcp's Avatar
The tab that you grind down.... is it now bare metal or did you re-powder coat that area?
BJK
Old 09-21-2013, 12:14 AM
SacCityCorvette
Supporting Vendor
I have emptied our sent and inbox and it still says 100% full. I'm working with a administrator trying to fix it.
Thanks for letting me know.
Christian
Old 09-21-2013, 12:17 AM
SacCityCorvette
Supporting Vendor
BJK
Hi,
We don't do anything to it because it is so small and the way we do it looks clean. I will post a pic for you went we do the next batch in a day or two.
Christian
Old 09-23-2013, 06:51 AM
VET4LES
VET4LES's Avatar
Old 09-23-2013, 04:14 PM
SacCityCorvette
Supporting Vendor
Thanks, its empty now.
Old 09-25-2013, 06:38 PM
SacCityCorvette
Supporting Vendor
Updated original post!
Old 10-02-2013, 10:11 PM
kedar
kedar's Avatar
St. Jude Donor '12
Very nice starter. Is the solenoid better than stock?
Old 10-03-2013, 02:23 PM
SacCityCorvette
Supporting Vendor
Hi kedar,
I'm not sure how to compare them. All I can say is, its shinny-er.
Christian
Old 03-07-2014, 04:53 PM
SacCityCorvette
Supporting Vendor
Sound clip from Mister Peebody using the ProComp high torque starter.
http://forums.corvetteforum.com/c5-g...ry-cool-3.html
Christian
To High Torque Gear Reduction Starters! Very Cool!
Old 03-18-2014, 08:03 PM
pauldreazy
pauldreazy's Avatar
So How much is this gonna cost for everything?
Old 03-18-2014, 08:06 PM
pauldreazy
pauldreazy's Avatar
Can anyone explain it simple? So what does this thing do?? Haha help
Old 03-19-2014, 02:19 PM
SacCityCorvette
Supporting Vendor
Hi Paul,
The starter has gearing in it that gives it more torque to spin the engine over faster.
Its $172.95 plus $22.50 to ship.
Thank you,
Christian
Quick Reply: High Torque Gear Reduction Starters! Very Cool!
