Need 08 C6 coupe manual steering column/ steering angle sensor wiring Schematic
Old 08-15-2013, 08:24 PM
red12secz28
red12secz28's Avatar
Default Need 08 C6 coupe manual steering column/ steering angle sensor wiring Schematic
As the Titles states. I recently did a clock spring and steering column harness replacement for steering wheel audio controls. The harness I got from gm was different so I rewired the new harness for the pinouts for the steering angle sensor. I am getting service active handling light now. Can someone help me out with a column/ steering angle sensor wiring schematic for 08 manual coupe. It would be greatly appreciated.
Old 08-18-2013, 12:14 PM
red12secz28
Any one?
Old 08-18-2013, 01:40 PM
Zoxxo
Zoxxo's Avatar
As I said to the other fellow, this is from my 2007 GM service manuals. All I can find is the connector diagrams so make of this what you will.
The steering position sensor connector:
http://www.darkmars.com/cf/steer_sensor_connector.jpg
http://www.darkmars.com/cf/ebcm01.jpg
http://www.darkmars.com/cf/ebcm02.jpg
http://www.darkmars.com/cf/ebcm03.jpg
http://www.darkmars.com/cf/ebcm04.jpg
Hope that helps.
Z//
Old 08-18-2013, 03:34 PM
red12secz28
I appreciate this a lot. A little guidance will help with troubleshooting. Thanks again.
Old 10-29-2013, 11:08 PM
red12secz28
Still no luck! If anyone one has the 2008 under dash connector from the steering column harness plus steering angle sensor to the under dash harness would be helpful. Thanks
Old 11-04-2013, 08:49 PM
red12secz28
Anyone? Can't get the CEL to clear from the wiring for the Steering angle.
Old 11-05-2013, 12:41 AM
RLSebring
Supporting Vendor
Support Corvetteforum!
RLSebring's Avatar
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Here's the pin out. Haven't been able to locate the schematic..
File Type: pdf
Old 11-05-2013, 12:57 AM
RLSebring
Supporting Vendor
RLSebring's Avatar
St. Jude Donor '17
There is also a problem with the connector in that the wires are sometimes loose and can set the cel Especially service active handling light. GM makes a comb style clip that is inserted into the connector and tightens up the pins.
Old 11-05-2013, 05:16 PM
red12secz28
Thanks for the pin out! I already have that info. I specifically need where the column harness meets to the under dash connector. Sorry if I wasn't specific enough.
Old 11-06-2013, 07:46 PM
red12secz28
Anyone?
Old 11-07-2013, 01:19 AM
RLSebring
Supporting Vendor
RLSebring's Avatar
St. Jude Donor '17
This is as close as I can find, Good Luck.
File Type: pdf
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
Old 11-07-2013, 11:05 AM
red12secz28
That is exactly what I was looking for!!! PM your paypal account so I can buy you a case of Beer. Thanks so much!
Old 11-07-2013, 01:07 PM
RLSebring
Supporting Vendor
RLSebring's Avatar
St. Jude Donor '17
No need, just glad that was it. Pay information forward when ever you have the chance.
To Need 08 C6 coupe manual steering column/ steering angle sensor wiring Schematic
Quick Reply: Need 08 C6 coupe manual steering column/ steering angle sensor wiring Schematic
