Exhaust Muffler Adjustment
Race Car Tech
The Exhaust outlet pipes are approx 12.5" center to center. I need to narrow this dimention to approx 11.0 " Is there an easy way to do this? Can the exhaust hanger rods on the muffler be manipulated to get the dimensions changed?
Or is this a job for the muffler shop people.
This is what and why I need to get the 11" center to center so I can fit this exhaust tip on.
[IMG][/IMG]
[IMG][/IMG]
Race Car Tech
The inlet pipe is exactly between the 2 ports, so I'm guessing 5.25" from each side, leaving 11" - 11.5" from center to center of the inlet pipes.
I've seen a behind view of this plate and the pipes are exactly between the 2 ports on each side.
I'm hoping someone has adjusted the mufflers from side to side before I buy this exhaust tip.
