Trans Flare Issue - Resolved
So just in case anyone else experiences this issue, I wanted to post up for reference.
My car developed a very bad, very consistent 2-3 shift flare. At 3k rpms it would sometimes jump to 4k between the 2-3 shift. Usually when the shift started at 3k it would be a 500rpm jump and then shift into 3rd. It was unbelievably annoying. It also didn't seem to be responding well, or at all, to changes in the tune. This has been happening for about 6 months and we tried retuning 4 times to correct it.
I finally got the A6 transmission rebuilt due to age (76k miles) and having the supercharger on the car (550rwhp) and figured it would take care of this problem as well. After the trans rebuild and re-tune it was worse than ever.
My tuner called his friend at one of the dealerships and he said it was a known issue that after flashing the trans it could develop corrupted sectors, so he came out to the shop and set the trans as if it were 100% stock tune from GM with all of the latest GM updates. The car drives like a dream now and hits shifts so fast it's ridiculous, and this is just with the latest GM updates to Torque Mgmt and shift characteristics. The guy from the dealership said to give it 200 miles and then tune it to be quicker and more aggressive.
Just sharing my results
I got the transmission rebuilt due to age and having the supercharger on the car and figured it would take care of this problem as well. After the trans rebuild and re-tune it was worse than ever.
Pitt
It made me very uneasy to drive the car hard with ~550rwhp not knowing if it would shift properly or not.
Can't wait to actually get the trans tuned now
If your buddy needs more info I can get more detailed information from my tuner on exactly what was done and post it up, but from my understanding all that happened was that they flashed it back to a stock GM calibration with the most current updates to correct the corrupted sectors.
Interesting info. Can you find out if when they flash it back to stock with the updates, they do just the trans part or does it put the engine tune back to stock alss. I wouldnt want to drive to the dealer, get them to do it, and then find that my engine tune has changed.
If it's as bad as my car was he must hate driving his car now. Having it flashed back totally stock to GM's latest calibrations breathed new life into my car.
Transmission controller is separate from the ECM so the engine side is not effected.
Also anytime a transmission is repaired etc, a clearing/fast adapt with a tech 2 should be performed.
I have the same problem and would like to get this fixed right.
Thanks.
I did confirm though with my tuner that what Road Rebel said is correct. This flashing of the trans effects ONLY the trans and there is no loss of engine tune.
My car is a joy to drive again. If any of you guys are having this issue I'd suggest looking into this fix asap Maybe contact a local tuner and they could direct you to someone they know at a dealership that is aware of this and will do it for you.
Received 2,061 Likes
St. Jude Donor '13
We've been told that the newer programs can't be installed in the older trannies, but that could be incorrect or perhaps the rebuild on yours allows it to take a 2013 program.
Looking for an education...
It must be the latest updates for the model year. Rebuilding the trans wont change the programming it can accept. That is in the TCM.
There was a TSB about this 2-3 flaring and when I rebuilt my trans one of the things I changed (and all the known builders will insist it is changed) is to update to the later, 2011 and up front pump. Since I did this I have no flares, although I changed some tune settings so that could be part of it too.
I need to get this done on my car because I have the same 2-3 flare. The flare gets bad as soon as I flash a new transmission tune on the car and then after driving the car for awhile it does it a lot less.
I'm a bit worried about this though because I have a 3600 torque converter and I wouldn't want this tune to mess everything up. I know tuning is required for torque converters so I'm a bit leery.
Thanks but even after driving the car for months at a time without changing anything the transmission will still randomly flare from 2-3.
Hope you get it sorted out.
Yeah I just want to see where I can go here in Pensacola Fl to get this done. If I go to any GM will they do this update to my tune? I definitely want to go to the right GM dealership for sure lol.
