Max tire width for an 05
Can you put wider than stock on the rear of an 05?
Like ZR1orGrand Sport?
I put a 305/30/19 pilot super sport on, because I am going to buy wider wheels. It looks idiotic and doesn't fit the stock tires properly.
295 is the widest, and the price difference definitely doesn't justify it.
[QUOTE=Ferocious C6;1584147007]Your post makes no sense. Please revise
Maybe you are concentrating too hard
Will C6 Z06 or GS width rear wheels fit on a 2005 C6
The Z06/GS/Zr1 Wheels will sit way outside the fender. The offset is built into the wheels. The hubs are in the same spot on the base car as the others.
You can fit a 325 on an 11" wheel with a perfect offset. The only perfect ones out there are custom and big money.
The Ace wheels and some others will put a 285 or 295 right at the edge of the body. Any wider and they will stick out.
