advice on rough idle with a/c on
Noticed that when I turned my A/C on today that the car starting shaking a bit only at idle has never done it before. As soon as I took off and maintained a constant speed it goes away. Anyone have this problem before? Car is a 2005 6 speed with around 50k miles if that helps. Thanks in advance!
is the ac cooling ? watch the pulleys spin while the engine is running. you may have a tentioner, harmonic balancer or even a compressor failing. the idle is controlled the the throttle body, try cleaning it also.
