What differential will fit into a 05 c6
want to know what will work and what will I have to change, want to go from 2.73 to 3.42 , I have tried to search other threads but cant get a clear answer. Threads get jack to ask about other year models. I have a 05 c6 with the a4 tranny. any info would be a help before I spend some bad money. Does gm make a factory gear to swap into that rear end , WHAT WILL WORK IS THE QUESTION ,,, THANKS IN ADVANCE
any idea what that 30 spline mainshaft for the A4 costs from RPM to use the Z06 diff and whether a stock size convertor will work with it. thanks Dan
Man seems like lots of questions and not many answers. But its really simple. What will i need to have to get a different rear end to work in my 2005 and what will i have to do to get it to fit
contact stanger383 he put a c5 342 manual rear in his 05 a4 c6 he made the mounts, or you can buy a c6 2nd generation 342 manual and buy the adapter from rpm, i got an 07 case and bought 1 2010 sidecover and 1 2008 sidecover and put my gears and diferential in them with the rpm adapter, i already had 373 gears in my 05 when it cracked the case
Are you looking for a differential to race or just gears? I have a diff from my 2005 A4 that has Z06 C5 internals with 42000 miles on them. They are 3.42 shot peened OEM GM parts. This diff is a direct bolt on for you. And Motive makes gears for your diff too.
Jeff
Jeff
