New! Trickflow LS3 Heads! 382 CFM!
Finally got the AR Headers with x-pipe installed. Without a tune, I got 25 rwhp. Then installed the Trick Flow cam and heads and with a tune my overall was +100 rwhp. Sounds and runs great!
http://www.youtube.com/watch?v=8mPd1...ature=youtu.be
Track Junky
dyno sheet
https://plus.google.com/photos/11410...MOlqM76g-6cqwE
371 rwhp stock
396 with AR headers, no tune
470 hp after cam & heads with tune
371 rwhp stock
Track Junky
Doesn't look to me that the heads did much for your numbers over the stock LS3 heads.
Solid car nonetheless. I bet it's a blast to drive now!
My ride made it into the most recent Vette Magazine. The cover listed the article "MORE POWER" and the actual article is titled "No Compromise". A couple of pics are in my folder.
dyno sheet
371 rwhp stock
371 rwhp stock
Which one would be best suited for the 21st Century Muscle Cars CMC 20 Camshaft specifications: 223/235 duration @ .050 .610/.620 with 1.7 ratio rocker arms 115.0 CL?
From the makers of the baddest cathedral cylinder heads on the market, comes the all new Trickflow LS3 Cylinder Heads!
Trick Flow engineers combined the best features of GM's LS3 and LS7 cylinder heads with their own unique brand of race-winning engineering and technology to create the ultimate square port LS cylinder heads for 4.000 in. and larger bore engines--the GenX 255 cylinder heads for GM LS3s. These heads feature fully CNC competition ported runners with a premium high-resolution surface finish for maximum airflow and performance potential. They have a 12 degree valve angle to increase piston-to-valve clearance and allow for the use of larger camshafts. These Trick Flow® GenX® 255 cylinder heads for GM LS3 are available with standard and 6-bolt per cylinder mounting patterns, as well as with fully assembled or bare castings.
Trickflow 255cc CNC Ported Cylinder Heads LS3, Steel Retainers, 400 lb Valve Springs $2,395 shipped
TFS-32610001-C01
Trickflow 255cc CNC Ported Cylinder Heads LS3, Titanium Retainers, 400 lb Valve Springs $2,495 shipped
TFS-3261T001-C01
Trickflow 255cc CNC Ported Cylinder Heads LS3, Steel Retainers, 465 lb Valve Springs $2,449 shipped
TFS-32610002-C01
Trickflow 255cc CNC Ported Cylinder Heads LS3, Titanium Retainers, 465 lb Valve Springs $2,549 shipped
TFS-3261T002-C01
Trickflow 255cc CNC Ported Cylinder Heads LS3, Titanium Retainers, 400 lb Valve Springs, 6-Bolt Pattern $2,495 shipped
TFS-3261T003-C01
Trickflow 255cc CNC Ported Cylinder Heads LS3, Titanium Retainers, 465 lb Valve Springs, 6-Bolt Pattern $2,549 shipped
TFS-3261T004-C01
TFS-32610001-C01
TFS-3261T001-C01
TFS-32610002-C01
TFS-3261T002-C01
TFS-3261T003-C01
TFS-3261T004-C01
- Increased Piston to Valve Clearance (12* Valve Angle)
- Includes new Rocker Arm Rail Mounts for use with OEM LS3 1.7 Rocker Arms
- Uses Powdered Metal Valve Guides
- Requires longer Pushrods (7.750")
#33
So funny. You are 100% correct. I thought my tires were soooo good and they were for a stock GS but now,,,,,,,,,no way. I really have to be careful and it's not a good feeling. Tires are in the near future!
#34
There's also a video at the end. The only problem is Vette Magazine called it a 2011 GS and it's a 2012. Oh well
http://www.vetteweb.com/tech/1402_tr...npTi-pCR2IW563
#36
GS sounds great, loving the lope. Which cam and heads did you go with?
#38
Former Vendor
I would recommend based on your cam specs the Trickflow 255 cc head with 400lb valve spring and the titanium retainers.
#39
Former Vendor
