Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-15-2013, 04:48 AM   #1
greenbeauty
CF Senior Member
Default Fob programming #1 short or long method?
I want to program my new fob for my C6..
The only fob I have is fob #2 (on the back) ..
I've bought a new one with #1 on it..
Can I use the short methode ?
Or do I need to do the erase all procedure ?
Short methode:
1. Put drivers window down all the way, then turn car off
2. Trunk open
3. Glove box open
4. Put working fob on console next to shifter (the one you are currently using to drive the car) IMPORTANT. Also make sure no cellphones are in the car.
5. Put key in trunk keyhole and turn key five times in less than 5 seconds.
6. DIC will now beep and light up and say “Ready for fob 3”.
7. Put new unprogrammed fob in slot by glovebox with buttons facing right (passenger) side.
8. Wait and watch DIC. When it says “Ready for fob 4” it is done. Up to four Fobs may be programmed to the car total.
9. When all Fobs are programmed, push OFF/ACC (bottom half of start button) to turn off DIC.
10. Test all four buttons on fob and then take away all other fobs and check car starting with new fob(s).
greenbeauty is offline   Reply With Quote
Old 05-15-2013, 10:34 AM   #2
eboggs_jkvl
eboggs_jkvl's Avatar
Long method and put the case with the #1 in as the first to be programmed.
Keep this handy..
>>C6 Fob Programming and Glove Box Slot Testing Procedures<<
Elmer
eboggs_jkvl is offline   Reply With Quote
Old 05-15-2013, 10:45 AM   #3
Bill Dearborn
Bill Dearborn's Avatar
Quote:
Keep this handy..
Elmer
If you use the short method the new fob will be programmed as fob 3 and it will not have access to all of the DIC key choices.
Bill
Bill Dearborn is offline   Reply With Quote
Old 05-15-2013, 11:40 AM   #4
greenbeauty
CF Senior Member
Mmm what dou mean with 'access all of the dic key choices??
What are those?...
Old 05-15-2013, 11:49 AM   #5
eboggs_jkvl
Quote:
What are those?...
When you are in the car with FOB #1 and have set your radio, side mirror, seat location, Welcome message on the DIC (mine has my name) etc. the car will remember those preferences the next time. If your SO uses FOB #2 and sets all of those things, the car will remember those when Key FOB #2 is used. FOBS 3 & 4 do not have that ability to program anything in the DIC.
Elmer
Old 05-15-2013, 12:21 PM   #6
cclive
CF Senior Member
cclive's Avatar
Exactly...#3 and 4 will only unlock the car and start it...seat position, radio stations etc etc will not be set as part of the deal. Use the full long procedure including the test of the glovebox slot...always a good idea before doing the long one.
cclive is offline   Reply With Quote
Reload this Page Fob programming #1 short or long method?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Comprehensive Fob Programming Instructions cclive C6 Corvette General Discussion 375 07-03-2014 05:39 PM
Another fob programming FAIL!! zildjianz06 C6 Tech/Performance 58 04-02-2014 07:43 AM
Programming Key Fob Trouble FastBlackSS C6 Z06 Discussion 19 08-31-2013 12:23 AM
How to Reprogram or Add a Fob Baxter's Dad C6 Corvette General Discussion 0 08-28-2013 07:04 PM
Key fob programming txvettefan C6 Corvette General Discussion 8 02-13-2013 06:50 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
