Random misfire only when crusing at low RPMs
Hello everyone,
When I'm cruising down the highway between 75-80mph (17-1900 RPMs) my 2005 A4 vette starts a random misfire, the car stumbles. If I give it gas it stops happening, if I let it happen as much as it once the car will eventually come out of overdrive and drop into 4th and stop the stumble. That is the only time I get a flashing check engine light.
Finally got the check engine light to stay on and I got these 3 codes:
P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1 ECM
P0300 Engine Misfire Detected ECM
P2119 Throttle Closed Position Performance ECM
Things I have tried:
Brand new spark plugs
Replaced the MAF (I had an extra)
-These fixed the car for about 24hrs with out a misfire then it started happening again-
Hello everyone,
