180mph!
Old 05-07-2013, 12:48 PM
Darkness1988
Darkness1988's Avatar
Default 180mph!
Hello all, I took my 08 coupe up to 180 last night and now the shifter feels like it has moved over to the left! It moves a tiny amount to get into first gear. There is lots of play moving it to the right going to fifth or sixth. It is a B&M short throw. Anyone have any ideas?? Maybe too hot??
Old 05-07-2013, 02:53 PM
HOXXOH
HOXXOH's Avatar
Received 2,058 Likes on 1,503 Posts
Those Mexican roads will do that everytime with the B&M shifter. Stay below 175 next time.
Old 05-07-2013, 03:38 PM
truckplay
truckplay's Avatar
for your own sake do not tell people you are speeding
when you had it apart did you remove or loosen the shifter box ?
that is what it sounds like.
Old 05-07-2013, 03:42 PM
LEAVINU
LEAVINU's Avatar
If you would have topped it out at 186mph you wouldn't be having these problems.
Old 05-07-2013, 06:29 PM
Darkness1988
"on a closed track"
I felt like it would have done more than 186, it was still going strong. I wasn't ripping through the gears. I started in 3rd. I hate the way it feels now. Ive had the short throw in it for 6 months or so but have not gone that fast, maybe 165 max at the track
Old 05-07-2013, 07:12 PM
Pfadt Racing
Pfadt Racing's Avatar
I talked to a guy that said his "shifter went to jell-o" from the heat at the track the other day. Sound about the same?
Old 05-07-2013, 07:25 PM
Ferocious C6
Ferocious C6's Avatar
Problem one is the B&M crap shifter.
Toss that in the trash, or at your worst enemy, and get a better shifter.
Old 05-07-2013, 08:18 PM
Darkness1988
Could be.
What do you suggest? I had hurst on my C5 and loved it but they don't offer it for 08+ C6.
Old 05-07-2013, 10:11 PM
acrc6
acrc6's Avatar
What do you suggest? I had hurst on my C5 and loved it but they don't offer it for 08+ C6.[/QUOTE]
MGW. None better.
mgwltd.com
Old 05-07-2013, 10:55 PM
child_of_fire
child_of_fire's Avatar
i think i had the same thing happen to me. it was the stock shifter though. it felt mushy iin second. loose and spongy. as the other poster mentioned, it was the shift box. screw came loose i guess it wasnt torqued down from the factory. anyway MGW went it after that and haven't looked back.
Old 05-08-2013, 07:41 AM
veloz
veloz's Avatar
at least he didnt post the vid on youtube....did you? ayaya
Old 05-08-2013, 08:49 AM
Ferocious C6
MGW. None better.
mgwltd.com[/QUOTE]
What he said. I'd honestly stick with the stock over the b&m. I made that mistake once, never again.
Old 05-08-2013, 09:09 AM
SinisterC6
SinisterC6's Avatar
Old 05-08-2013, 09:25 AM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Why not, I did.
On the Dade Collier Training runway during the Miami Mile event of course!
I did not have any shifter issues after three of these runs (nor 494 drag strip runs for that matter).
I have seen friend shifters "turn to mush" on the road course when they overheated their transmissions. I can tell you, since I have a tranny temp gauge in my car, if you went up to 180 and then back down...you didn't overheat your transmission. Takes longer than that...20-30 minutes at high rpms like road course use can do that. Both of my friends who had that problem on the road course ended up replacing their transmissions.
In your case I would bet your shifter moved or your shifter box came loose. Also look at the bushings on the shifter box, they wear out after a while and cause the shifter to be loose. If I was you I'd take the shifter out and check it and the box. Zip sells replacement bushings.
Old 05-08-2013, 12:42 PM
Darkness1988
nope!!
Thanks for the replies, I will have to get the MGW!!!
Old 05-08-2013, 01:45 PM
07_C6_WPB
07_C6_WPB's Avatar
I agree MGW!
Here is a quick 140mph run....
Old 05-08-2013, 01:54 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
^^^ I'll call you on that 140 run...
To 180mph!
Old 05-08-2013, 08:45 PM
timd38
timd38's Avatar
MGW. None better.
mgwltd.com
What he said. I'd honestly stick with the stock over the b&m. I made that mistake once, never again.[/QUOTE]
Same deal here. Bought a B&M, junk, MGW really good!
Old 05-09-2013, 12:11 AM
Ferocious C6
Hurst is also crappy and saying it is one step above stock is being nice. To me they are not worth the money. But that has been my experience with them, that they suck. Especially once you've drive the same car with a good shifter.
Old 05-09-2013, 05:17 AM
rokn91rs
rokn91rs's Avatar
Check the bolt that holds the shifter to the rod that goes to the tranny. It's a torx head I believe not sure what size. Sounds like it may have come loose.
Quick Reply: 180mph!
