question about corvette C6 header and O2 sensor
Old 04-21-2013, 02:37 AM
c6bhr
Cruising
c6bhr's Avatar
Default question about corvette C6 header and O2 sensor
Good evening.
So i installed the dynatech headers on my C6 .. how ever i didnt find the front O2 sensor port ... only the rear ones which are locted at the end of the headers
Currently the front o2 sensor is not connected .. can i use an extension and connect the front ones in the rear ports?
Or are the ports there for the front o2 sensor ???
The rear ones which have been located behind the catalytic converters. Installed headers W/O aftermarket catalytic converter
Thanx
Old 04-21-2013, 06:51 AM
c6bhr
Cruising
c6bhr's Avatar
Bump
No one ever installed headers lol
Old 04-21-2013, 07:25 AM
trikeffex
trikeffex's Avatar
The O2's in the header collector are for the front 02's..The rear 02's should be in your X-pipe....
http://www.dynatechheaders.com/instr..._C6_05to10.pdf
Hope that helps!!
Charles
Old 04-21-2013, 10:30 AM
haljensen
Support Corvetteforum!
haljensen's Avatar
Originally Posted by c6bhr
Good evening.
Thanx
"..only the rear ones which are located at the end of the headers"
The ports mentioned above ARE the front O2 ports.
The rear O2 ports are in the next section of pipes.
Front is before the catalytic convertors, rear is after the catalytic convertors (or anyplace after the front ports) .
Old 04-21-2013, 02:10 PM
c6bhr
Cruising
c6bhr's Avatar
yea i got the extension harness installing it tomorrow ... the thing is its a PITA to install while haeders are on the car
To question about corvette C6 header and O2 sensor
Quick Reply: question about corvette C6 header and O2 sensor
