New Tires Rear End Not Centered
So I just upgraded wheels and tires to 19x11 +79MM and 325/30R19. Here's the issue, on the driver side, the tire sits nicely in the wheel well about 1/8" from the fender. On the passenger side, the tire sits just outside the fender about 1/8". I thought maybe I was sent a +73MM wheel, but I swapped the wheels and the Passenger side is still slightly outside. Question is, has anyone ever seen this issue and do you think a simple alignment will resolve it? I never noticed anything wrong with handling and my old tires never wore funny. Just looking for some feedback.
You will need an alignment but more also, the rear cradle needs to be moved over a bit. there are four bolts that hold the whole thing in. your shop will need to loosen it and shove it over there are pins in the frame to hold it in place and you may need to slot the holes a bit if it won't move enough. Then realign
Is this something that can happen frequently or could have come from the factory this way. I bought this 2010 used with 6700 miles on it and it was clean (no accidents reported) and it didn't appear to have been wrecked.
Just curious as to what can cause the cradle to shift.
I experienced this when I went with the LG Challenge rims and 305 width tires in the rear.
Enough to bother me and went back to OEM rims and tire size.
Mustangs have the same problem I am told.
It is not noticeable with stock set up but if you look close you will see the discrepancy even
then.
then.
Received 8,919 Likes
Is the off set at the front and rear of the wheel or is it just at the front? If it is just at the front the rear thrust angle could be off which would make the car dog walk just a slight amount. Thrust angle is adjustable with rear tie rods and is adjusted when setting the rear toe during an alignment.
Bill
Bill
It doesn't really bother me and I thought it was probably normal. I can live with it. Just wanted to make sure everything was normal. The alignment guy said everything was perfect after they did the alignment and showed me print outs of the work they did. If you're in Louisville, LFM is a pretty good place to take your ride for things as such. Thanks for everyone's input.
With me set up one side was even with fender lip and the right side was out of lip.
This was with 305 width tires on 10 in rim but with non OEM off set.
With tires tucked inside it is not as noticeable.
Yeah, that's when I noticed it. I went with 325/30 PSS' on 11" and when I did, that's when I noticed it. I had an alignment done and it was corrected somewhat when they corrected the toe on the drivers side rear. It brought that tire more out towards the lip than it was. So, it looks pretty damn close now. I was just wanting to check with the members here to see if anyone had encountered this in the past with their upgrades. I'm happy to know that nothing is wrong with the rear end and that these come from the factory with a slight offset in the rear end.
Location: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
My concern would also be the sandblasting to the paint you are going to be doing to the tire that is sticking outside the fender.
Does anyone have the torque specs on the rear cradle bolts? I plan to try and move mine towards the drivers side to get the tires center (the pass side sticks out a little) because I am running 315's on the rear.
TIA
TIA
As far as the cradle misaligned from the factory, I wouldn't doubt that for one second. With GM's lousy tolerances, you'd have to have the entire tire outside the fender to be out of spec . Yes, I exaggerated a little, but unfortunately, not that much. But any decent alignment shop can leave the THRUST ANGLE at or very close to 0.00º, which is what you want. Alignment tolerances for the Vette as absurd, so you also need to tell the shop you want the job done a lot more accurate than the lousy GM specs, even if they charge you a bit more. Just the camber spec alone is -0.45 +/- 0.60º, if you can believe that. That's simply ridiculous. Good luck man.
I'm having the same concerns!!!
May 1, I got these installed at my shop with tune and new headers:
Vossen 19x9.5 silver with chrome lip fronts(N)
Vossen 20x11 silver with chrome lip rears(N)
245/35/19 Michelin super sport front tires(N)
295/30/20 Michelin super sport rear tires(N)
Upon inspection, I noticed the back tires were outside the rear fenders by about 3/8" on drivers side and 1/2" on passenger side. I mentioned it to the GM shop and he never has seen this before.
So, I figured it was up on jack maybe would setlle etc... but it has not. It doesn't pull so I figured it could just be the fenders were a little off.
I am glad to read this is NORMAL and I couldn't notice the difference with OEM sized tires.
Yet, mine seem to be more outside the fender than the other posts. Should I be concerned?
Any comments fro the experience or experts Vette owners shops? Thanks this forum is so darn helpful. My wife says I'm obsessing about the Vette since I'm always on the forum. I told her I am learning more and more about the coolest Car I have ever owned. And, I have had this first vette for almost 5 years now.
