Valve Lash Adjustments
Hey guys and gals,
If you ever decide to replace your OEM rockers with some adjustable one's and need to adjust the valve lashes, you should check out this tool from the website below to help you do that. It is simply a magnetic vinyl strip with graphics on it that wraps around your harmonic balancer or a pulley that shows you each valve to adjust. I used one for my C6 after I replaced the OEM rockers with a set of Comp Cams 1.85:1 rollers and after adjusting all of them, the engine started up quickly, ran smoothly with no noise, and I have yet to do any readjustment anytime afterwards.
It's pretty cool, cheap and I was very happy with it. Anyway just thought I would let you know about it.
