FAST LSXR Intake Manifolds on Special at RDP
Former Vendor
RDP Motorsport is Offering Some Huge Savings on the Fast LSXR Inlet Manifold. WE WILL NOT BE BEATEN ON PRICE!
50 State Legal Intake - C.A.R.B - E.O. D-279-8
FAST™ engineers teamed up with the airflow specialists at RHS® to develop the LSXR™ Intake Manifolds for cathedral port LS1/LS2/ LS6 engines and rectangular port GM LS3 and LS7 engines. The LSXRT™ Intake Manifold was developed for the GM 4.8/5.3/6.0L cathedral port truck engines and cathedral port LS1/LS2/LS6 race applications where hood clearance is not a concern.
Constructed from an advanced polymer material that offers a host of benefits over aluminum aftermarket intakes, including lighter weight, increased strength and improved heat dissipating characteristics.
102mm air inlet that is perfectly suited to the FAST™ Big Mouth 102mm Throttle Body™, but the manifolds can also be used with any OEM or aftermarket 4-bolt 90mm or 92mm throttle bodies.
Innovative multi-layer design with removable runners for quick and easy disassembly and porting, integrated nitrous bungs and a precise bolt-on fit that permits the use of factory accessories and OEM fuel/emission connections without adjustments or clearance issues.
When used with a Big Mouth 102mm Throttle Body™, the LSXR™ Intake Manifold produced gains of 16+ Horsepower on a near stock LS7 engine and 26+ Rear Wheel Horsepower on a 500cid RHS® LS Aluminium Block based engine
Part Number 146102 (LS3, L99 & L76):
Fits LS Rectangle port cylinder head equipped applications (LS3, L99 & L76)
Drive-By-Cable Throttle Body Options
Big Mouth 102mm Throttle Body™ Part # 54102 or Big Mouth 92mm Throttle Body™ Part # 54092 for drive-by-cable applications1
Fuel Rail Options
LS3, L99 & L76 Engine:
FAST™ Billet Fuel Rail Kit (LS3, L99 & L76) Part # 146027-KIT
FAST™ Fuel Injector Spacer Kit for OEM Rails Part # 146025-KIT
We are also Offering 12 Months Interest Free Terms and Free Shipping to your Door.
Fuel Rail Options
Former Vendor
Can you beat this price...
http://www.ebay.com/itm/Fast-102mm-Lsxr-Ls1-Ls2-Ls6-Car-90-92-102-MM-Intake-Manifold-146302-/140934709739?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d05d01eb&vxp=mtr
Former Vendor
Fast 102mm LSXR LS1 LS2 LS6 Car 90 92 102 mm Intake Manifold 146302 | eBay
