no fob dected doors will not open
Cruising
Hi im new to the site having a few problems with my 2008 z51 when its cold outside doors will not open and message says no fob detected also get service active handling message brake lights come on and stay on until you depress the brake then it goes out.then today car wouldnt start at all would only click keep tryin finally started.extended warranty ran out last month.:any recalls on any of this?any help thanks in advance kenney
no recalls for those. here is the recalls...
TSB Number & Issue Date TSB Title
09230B MAY 10 Recall - Roof Panel Separation
06041C MAY 07 Recall - Body Color Roof Adhesive Separation
10037B MAY 11 Campaign - Unwanted Repeat Calls To OnStar(R)
i know we can help here but seriously, i think your going to need to take it to a dealership that can test with proper Tech2 equipment.
it might be as simple as a bad battery connection, or bad/fried positive connection to the starter.
but with a cehck engine light on, it will have codes that Tech2 can read and will tell the story.
you can try ideas here, but unless its the battery/battery connection, Tech2 dealership would be my personal solution.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,832 Likes
2015 C7 of the Year Finalist
>> FOB not detected checklist <<
Elmer
OP found part of the problem, per his other thread...
Yesterday, 07:22 PM
kdt55chevy
Junior Member
2008 Chevrolet Corvette
found at least one of my problems today starter solenoid burnt at battery cable connection.ordered new solenoid hope to have it fixed tomarrow thanks for all the help kenney
Yesterday, 07:22 PM
kdt55chevy
Junior Member
