Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Why is My Corvette Stuck in Park?
Guide to diagnose trouble with recommended solutions.
2005 C6 auto's stuck in Park, solution with pics.
#62
In a bind you can punch downwards with a closed fist to pop it in to gear I did this for 3 days when I was stuck in LA. Think like a hammer on top of the shifter 3 hits usually work for me! Iam on my 3rd shifter for an 07 just hit 60000 miles
#63
If you tied the locking pawl back in the first place you'd still be on your original shifter.
#64
#67
If you tip that piece back a quarter of an inch you are all set. I'm not sure I would completely break it off. We did this to my father in laws 2005 and by doing it right and not cutting out any steps it took us a little less than 2 hours.
#68
yeah... I just tied mine back also.
#69
#70
lol..i was just messing wit cha...your clock spring must be wound a little tight. it's the innerweb...relax.
#72
Locked in Park
I have been off the Forum for awhile due to lost user name and password, but I have read the blogs on this issue. Following is my response.
I have a 2005 C-6 which suffers the locked in park syndrome for the past 8 years. 7 years ago I took it to a dealer (Weseloh Chev. in Carlsbad CA). The young technician was determined to find the problem. After a look, he called me back to his work site and together we went through the entire circuit that affects the shift lock solenoid. The results narrowed the problem down to the brake light solenoid located under the passenger side floorboard. When the resistance builds up in this solenoid, the voltage drops and is not sufficient to actuate the brake lock solenoid (in the same circuit) thereby locking the shift lever in Park.
The simple fix when the brake solenoid starts locking up is to replace the brake light solenoid. I buy them at dealer parts for about $6.50 and always carry a spare. Simply lift the floor board forward, unplug the little square brake light solenoid and plug in a new one. Easier than changing a fuse. This usually solves the problem until the new solenoid builds up resistance again causing the shift lock solenoid to fail.
Hope this helps.
Hope this helps.
outagas (01-17-2016)
#73
Hope this helps.
Hope this helps.
#75
There is another thread on here where they quoted the owners manual saying a workaround is ...
Manual sez:
1 put the car in accessory mode
2 apply and hold brake till end of step 4
3 shift to neutral
4 start the engine and shift to wanted gear
I found that this works for me now but not necessarily the first time. If I climb in the car almost ALWAYS now it exhibits the stuck in park problem.
After finding this post - it seems as if I just put the car into and out of accessory mode you can HEAR the solenoid attempting to disengage the lockout - I do it a couple - three times and bingo - I put my foot on the brake (in acc mode) pull it back to neutral - start it - and good to go.
A good work around for now until I get to a more permanent fix or workaround.
Manual sez:
3 shift to neutral
#77
Hope this helps.
Hope this helps.
Im currently experiencing the issue prolly 25% of the time. When it occurs, you just play with it for less than 30 seconds. It has occurred prolly 100 times now, but has never taken more than 30 seconds to move outta park.
#78
You like living dangerously. It took only about 10 times for me to decide to take the sucker apart (center console) and tie the locking dog back and away from the shifter gear.
Worth every minute of my time to get what I experience now every time I get in the car: Peace of mind.
I like living stress free.
#79
sticking gearshifter
I have the same "wont shift out of park" problem with my 2008 C6, whereas I never once had the problem with my 2005 C6. Because I didn't get an extended warranty, ive spent hours reading these forums, and there has been no easy solution. However, I've noticed that now that I'm driving the car daily, the percentage of problem occurences have significantly decreased. Previously, I was only home driving the car on weekends. Also, the car has never totally failed...it always gives in and complies within 30 seconds.
I have a 2005 corvette with a sticking gear shifter and has gotten worse through the years, after trial and error through experimentation i believe i may have found a quick and easy fix for everyone, spray wd-40 or silicone spray using an injector tube into the corners of the push button **** of the shifter, Run the shifter through all the gears a few times and that should do it, my problem has been resolved , hope it works for you as well, joe.
#80
