What was the hottest stock cam on an LS1,2,6,7?
I'm contemplating a kind of unusual project. I have an 05 C6 Z51 with an MN6 and therefore an LS2 motor. She has put down 373rwhp with only a Vararam, Maganaflow, 160deg stat and a tune at 41k mi.
I want to see how high in can get the rwhp using only stock or modified stock parts. The parts can come from any of the pre LS3 series engines (including the LS7 because it was a contemporary of the LS2) but must have been offered as a stock part. I know this will sound kooky to some of you. But I want to see what GM could have built without the internal corporate restrictions that were no doubt in place. I do my own labor so that's not a factor of me.
I already have a ported throttle body and a ported LS2 intake manifold ready to install. I also have LS7 exhaust manifords and cats. I plan to have the 243 heads ported (our buy ported ones). I also happen to have an LS7 cam and springs. I'm just not sure that cam is the best choice. I know that the 02 and up LS6 cam was more aggressive than the one used in the LS2.
Any thoughts out there on what stock cam is the best to use? For that matter any other thoughts on what else can be done to squeak a few more ponys out (1.8:1 rockers out of an LS7?)
H
H
H
H
Does anybody know if the LS7 exhaust rockers will work in an LS2? The intakes are offset so I know those won't. Are the exhausts straight or is there a slight offset?
H
H
I thought the LS6 manifold used a smaller throttle body.
Good to hear the rockers should work. I will upgrade to the LS7 lifters and push rods as well assuming the geometry works out for the lifter/pushrod/rocker/sping combination on a 243 head?
H
