Check engine light
Check engine light
I have a 2005 Corvette Coupe and recently the check engine light came on(steady). The OBD says there are no codes. I de-powered the cmptr by disconnecting the battery for about 10min and then re-connecting it.
The check engine light extinguished itself, but after about 3hr of driving the light came on again. Any ideas? thanks
Are you saying you put a OBD code reader on the OBD port and no codes were found? Try going to a auto parts store and use their OBD reader. They usually loan them out for free and hold your driver's license. Perhaps the one you have was bad or misconfigured?
