Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-30-2012, 02:18 PM   #1
Cory1745
Junior Member
Cory1745's Avatar
Default C6 not changing between driving modes anymore
I can only turn traction control off/on, I can't go into competitive driving mode or turn traction control/active handling off anymore. It has always worked fine, the only thing that has been done since I noticed it not working is I had the battery changed. I had to reset my windows & all my radio presets so I'm wondering if it affected the driving mode button. I wouldn't think it would but I've been wrong before. Car is a 2005 C6 z51 m6 3lt
Cory1745 is offline   Reply With Quote
Old 11-30-2012, 02:26 PM   #2
Cory1745
Junior Member
Cory1745's Avatar
Also I do not have any service lights or anything abnormal displayed in the DIC..
Old 11-30-2012, 03:18 PM   #3
JasonS5555
CF Senior Member
Support Corvetteforum!
JasonS5555's Avatar
I'm sure that the battery change wouldn't affect the way the TC button functioned. It sounds like you potentially have a failure. Do you have any way to read error codes?
Jason
JasonS5555 is offline   Reply With Quote
Old 11-30-2012, 05:03 PM   #4
Cory1745
Junior Member
Cory1745's Avatar
I have a actron OBD ll scanner but it says no codes. after researching through google I finally come across a forum that says if any of your tps sensors aren't reading or it says to service your tps system that it wont allow you to select any mode other than traction on/off due to something with the active handling system. With that being said my left front tire is reading 0psi through my DIC & it has 35psi in it. It was reading fine before I changed the battery because I have a slow leak in my back left tire (have some new tires ordered) so I constantly check it from habit. So once I get my tps sensor reading I will know if that is the problem or not. Thanks for the reply
Old 11-30-2012, 05:47 PM   #5
cagotzmann
CF Senior Member
cagotzmann's Avatar
Default Just Drop the tire pressure to 20 PSI
Quote:
After changing the battery I found that dropping the tire pressure to about 20PSI or until the unit starts reading on the DIC again should work. Then re-fill to proper pressure. I had the same symptom no driver modes.
cagotzmann is offline   Reply With Quote
Old 11-30-2012, 06:05 PM   #6
Cory1745
Junior Member
Cory1745's Avatar
Quote:
I will try that, I have Nitrogen in my tires so I will run by a tire shop tomorrow & give it a shot.. Thanks for the reply
Old 11-30-2012, 06:33 PM   #7
haljensen
CF Senior Member
haljensen's Avatar
If you have the original Tire Presure Sensors they are getting old, projected battery life was 10 years but who knows when the batteries were manufactured. Might be time for new TPS.
haljensen is offline   Reply With Quote
Old 12-02-2012, 12:28 PM   #8
Cory1745
Junior Member
Cory1745's Avatar
Just to update anyone incase they ever run in to this issue, once my tps sensor started reading again I regained control to my driving modes. Everything back to normal. Thanks for the replies
Old 12-02-2012, 12:46 PM   #9
Joe_G
St. Jude Donor '08
Joe_G's Avatar
My left front battery went out after 5 years as well with the same symptoms.
Joe_G is offline   Reply With Quote
Reload this Page C6 not changing between driving modes anymore
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help with driving modes on C7 Z51 with MSR golfbone C7 General Discussion 0 07-05-2014 12:03 PM
Competitive mode questions MaxPlusTen C5 General 13 12-24-2013 06:35 AM
Help please - Stabilitrak vs Performance Traction fieldre C7 Tech/Performance 2 12-15-2013 11:17 PM
Best driver mode to launch in? ck9887 C6 Corvette General Discussion 4 12-11-2013 10:53 AM
Need some help with a couple of DIC codes notnuts16 C5 General 2 09-30-2012 06:18 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
