Oil PSI spiking???
Oil PSI spiking???
Had my 2012 GS since may. Car has 2,800 miles. Love it to death! Took it out for a drive today, and noticed that the oil pressure (usually 40 PSI if I remember correctly) would spike to 80 PSI plus on acceleration. Took it straight to the dealer to look into it. My OnStar monthly report said oil life is at 59% life. Any ideas as to what is going on?
55psi is completely normal crusing at normal operating temps for the GS. Its supposed to be 15psi higher than the wet sump if you have the dry sump.
Not being rude, but how is it normal? It has never done this before. It just started for the first time today. Something had to have changed to cause this to just suddenly start happening.
completely normal at WOT. not to worry. My 11 GS does the same thing. And this topic pops up every few weeks with a new GS owner thinking that something has gone wrong.
Since I have had it (5 months) I have never saw the PSI budge from right around 40 PSI. Dealer said they would look into it, and it might be a sensor or something like that. Said 3-4 hours to fix it!
Nope. I know this to be normal. Both my dad and I have dry sump GS cars, and so does one of my friends. It happens on all those cars, and my tech also said it was normal when I asked him about it last year. So I still say normal, but ultimately taking it to the dealer is what should be done to confirm.
I can assure you that I am very attentive to my gauge cluster! But Dealer should have it back to me later today. Hope they figure out something on it!
oil pressure sender slowly failing, eventually reading 120+ psi on the dic.
my original sender died after good years of service, but every other gm sender i've had in there afterward has failed in less than 2 weeks.
the aftermarket one from kragen is stout, plus it has lifetime warranty
UPDATE
So I picked the car up this morning after a 12 hour mid. Started the car up to leave, and it did the exact same thing! PSI pegged at 80! Never done that in 5 months! I was so mad and tired I just drove it straight home. Paperwork said dealer found a "intermittent open in the oil pressure sensor" and replaced the sensor. Also stated N4585 w1.4W add w0.3W diag time. Just not sure what the heck is going on! It spike at startup and upon normal acceleration. At cruising speed, it settles back down to the normal 40 PSI. Again, never did this except for the last 2 times I have driven it! Also, car was spick and span when I dropped it off, and on the drive home, I could see a layer of dust with what lookes like a mechanics mat or something that had been place or dragged on the hood in a semi-circular motion so as to leave a nice dust streak! Not sure if it scrathed the paint or not, to upset to look into that at the moment. Am I a big whiny B@TCH about all of this? Is this normal? Weather was nice, and car was still doing it well after it had warmed up.
UPDATE
MilehiDenver, is your vette a dry sump engine? I lost track during the reading.......
Most of the folks replying have dry sumps (as I do), and they peg the needle frequently, when the oil is cooler.
But I had a wet sump LS3, and it would never do it.
OP as RPM goes up so does oil pressure to a point. On a dry sump motor you can see 80 - 90 psi especially if the oil is only warm.....
Mark
Mark
Good to here that it is normal. Still weird that I never saw this happen until last week. Not sure what the dealer replacing a bad sensor meant if nothing changed with the way it has been reading it out! Guess I will let it go now. Thanks for the responses!
