Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-17-2012, 08:03 PM   #1
jimrdunham
Junior Member
Default How to Remove c6 fuse/relay box
Looks like the under hood fuse box is easy to remove. Once it is loosened from the holder, there are 4 connectors on the bottom. I don't want to force them, how are they removed?
jimrdunham is offline   Reply With Quote
Old 10-17-2012, 09:01 PM   #2
DSOMC6
CF Senior Member
DSOMC6's Avatar
Quote:
Not sure if I can give you a clear picture but....
Have you already separated the top half of the fuse block from the bottom via the clips on the sides?
Once you separate the top from botom half, underneath the top half there's a plasic cover over each separate rectangular module (for lack of better words). The plastic cover simply unclips from each module. Then you unscrew whichever module you are removing via one of four screws. The screw routes down through the top of the fuse block, between the fuses/relays, down into the particular module. This will allow you access to the wiring connectors.
Edit: if you are just looking to get the entire fuse block/cover out of the way slightly but not get to wiring, there are screws/nuts holding it down.
DSOMC6 is offline   Reply With Quote
Old 10-17-2012, 09:21 PM   #3
jimrdunham
Junior Member
Hi DSMOC6, thanks for the reply.
Let me try to clarify what I'm doing. I want to remove the fuse block and either replace it or modify it based on a low beam problem that was described in another post.
I have separated the top and bottom with the the 4 clips on the the sides of the box. I was then trying to remove the plastic covers (rectangular modules) but I didn't want to force them for fear of breaking. If I understand correctly the plastic covers should just pop off with a screw driver or other tool and unscrew the 4 modules to remove the box, is that right?
To replace the new box I just do the reverse.
Thanks again for your help.
Jim D
Old 10-17-2012, 09:48 PM   #4
torquetube
CF Senior Member
Jim D
Each of the four prominent screws arranged in a row down the center of the fusebox secures one of the big harness connectors on the bottom.
Here's the trick: to remove one of the connectors, loosen its corresponding screw and back it out until it's almost removed. Then push down on the loose screw to pop the connector out the bottom. No prying or pulling on the wiring is required.
torquetube is offline   Reply With Quote
Old 10-17-2012, 11:02 PM   #5
DSOMC6
CF Senior Member
DSOMC6's Avatar
Yes Jim, the cover is just snaped in place. A small flathead screw driver to gently pry it apart works fine. I had to pull mine apart to get to the fuel pump wire that was intermittently shorting out. Wire and connector looked fine once I opened it up. So I just bent the connector back for more snug fit, a little dielectric grease and it was good to go.
If you have to pull wire(s) loose, there are plastic locks on the side that hold the connectors in place. Be careful not to let other wires escape as it's a cluster**** of wiring. Better yet take a couple pics so you know which wire goes where just in case one escapes.
Good tip.
Old 10-18-2012, 09:39 AM   #6
RLSebring
Supporting Vendor
Support Corvetteforum!
RLSebring's Avatar
Robert Sebring Robert Sebring
IIRC those covers don't have to come off. Once the box is seperated do as mentioned above in loosening each bolt at the top of the fuse block till loose then push the bolt down and the module will pop loose. Also each of the four blocks will only plug in one way and will only reach to just where it's going.
RLSebring is online now   Reply With Quote
Old 10-18-2012, 02:24 PM   #7
jimrdunham
Junior Member
Thanks for the tips. I'm going to work on it this afternoon and hopefully get it back together today.
Jim D
Old 05-11-2013, 02:31 PM   #8
SirVenox
CF Member
Jim D
Same thing Im going to try! Thanks all for this info. I was missing pushing the bolt down.
Let me know if you solved the low beam lights problem. I have the same problem along with the gauges problem (fuel, oil, tach, rmp, battery etc...) they are all dead. Im not finding anythin related to the gauges, only the lights.
SirVenox is offline   Reply With Quote
Old 06-20-2013, 08:35 PM   #9
jvc6
Junior Member
jvc6's Avatar
How did it go for anyone? I'm having the same headlight problem. I was able to remove the fusebox, but now how do I get the actual fusebox open to see all the wires? Apparently the fusebox problem is a common issue. You have to repair some of the connector wires. A local vette shop is charging $480 for the fix. I feel I can do it myself if I can get into it. With the fusebox out, I see no more clips or screws. There's a place towards the top where I can get a flat head in, do I just pry it apart? I applied a decent amount of pressure and it didn't budge. I didn't want to break anything. Any info helps. Thanks guys.
jvc6 is offline   Reply With Quote
Old 06-20-2013, 10:33 PM   #10
07MontRedcp
CF Senior Member
07MontRedcp's Avatar
Quote:
Have a look at this installation guide for an APS TT setup:http://airpowersystems.com/corvette/...tall_guide.htm
Page down to step 92 and go from there.
BJK
__________________
APS TT 630 rwhp/654 rwtq @ 10 psi
'07 Z51, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). ZR1 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, LG GT2 Coilovers, Autometer Cobalt Fuel gauage, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system. RX dual valve catch can.
07MontRedcp is offline   Reply With Quote
Old 06-20-2013, 11:34 PM   #11
jvc6
Junior Member
jvc6's Avatar
BJK
Thanks for the quick reply. Yeah I got that far. I had the top part of the fuse box out. But on that back side of that top part are just the prongs that the 4 looms plug into. I assume the wiring issue is inside of the top part of the fusebox that the relays and fuses plugin to but there are no clips or screws to open that. I took out all the fuses and relays in the area of the headlamp relay and sprayed contact cleaner in there but that did nothing. I'm going to take another stab at it tonight. I'll take some pics if I get it open. If I press on the relay while headlamps on the headlamps do come on and off. If I turn that main bolt also. So the problem is definitely in there. I bought this Vette 9 days ago and haven't been able to drive it past sundown (as is).
Old 06-21-2013, 09:16 PM   #12
jvc6
Junior Member
jvc6's Avatar
Okay, so I took it out again... Those large 4 screws that hold the top of the fusebox into the 4 looms below have the washers riveted on the ends so they don't come completely out. I took the whole fusebox off and out and was working on it on my couch (haha) but the fusebox itself won't pry open because of those 4 screws. They won't actually screw out, they screw into the looms but the riveted washers keep them in there. I even tried hammering them out somewhat to pop the rivets but I didn't want to hammer too hard and break the unit. So I have no idea how the repair shops get it open. And of course they won't share that secret with me, hence their $480 fee. So I'm out of ideas. Guess I'm just going to have to pay.
Old 06-22-2013, 12:23 AM   #13
cclive
CF Senior Member
cclive's Avatar
There is no secret that they know that is unknown here on the forum...someone here will help. I would if I had ever been into the fuse box.
cclive is offline   Reply With Quote
Old 06-22-2013, 06:14 PM   #14
ssmith1118
Junior Member
Default C6 Low Beam Issue
I have been researching and following this issue for nearly a year now. The best source of info I have found is on the NHTSA website where over 40 complaints(including my own) have been filed by owners of 2005-207 C6 Corvettes with this issue.GM is currently supposed to be responding to the NHTSA's investigation by July 1, 2013 unless they request an extension. You can follow the research and GM's response by searching for investigation PE 13-013 on the NHTSA's website.
ssmith1118 is offline   Reply With Quote
Old 06-22-2013, 07:38 PM   #15
bheathcoe_07
CF Member
bheathcoe_07's Avatar
I now have this dreaded issue as well. Low beams work in the morning for about 10 mins, then go out. Replaced the relay and made sure stalk and auto sensor were good. Found a new fuse box on Ebay for $200, but don't want to buy and have the same issue. I am attempting to remove the fuse box as the OP is, but what is it you are looking for? Burnt wiring or bad pins?
bheathcoe_07 is offline   Reply With Quote
Old 06-22-2013, 09:21 PM   #16
torquetube
CF Senior Member
Everything you ever wanted to know about taking the C6 fusebox apart, with pictures.
Old 06-22-2013, 10:48 PM   #17
cclive
CF Senior Member
cclive's Avatar
I just knew that someone would come through...
Old 06-22-2013, 11:45 PM   #18
cclive
CF Senior Member
cclive's Avatar
Do we know what causes that wire to break???
Old 06-22-2013, 11:50 PM   #19
torquetube
CF Senior Member
Quote:
Probably work hardening due to repeated bending caused by thermal expansion and contraction. They always break in the same spot.
Old 06-23-2013, 12:26 AM   #20
cclive
CF Senior Member
cclive's Avatar
That is really wild...and it doesn't look like there is anything unusual about that particular bend...there are lots of bends that look the same...someone deserves lots of credit for finding that tiny break.
Reload this Page How to Remove c6 fuse/relay box
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fuse Box Help - 58 Corvette Bomba_MC C1 & C2 Corvettes 4 05-04-2014 08:06 AM
Fuse box Cover screw-removal? 99TorchTop C5 Tech 8 03-09-2014 01:05 PM
Exhaust Fuse shekmark427 C6 Corvette General Discussion 22 11-10-2013 09:58 AM
2 silly questions markiemark C5 General 4 04-29-2013 05:11 PM
Help With passenger side fuse box please? Cobalt502 C6 Corvette General Discussion 6 03-31-2013 08:12 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
