How to Remove c6 fuse/relay box
Old 06-24-2013, 12:55 PM
jvc6
Cruising
jvc6's Avatar
I just knew that someone would come through...
Well...I wish I would have gotten the notifications to these replies. haha Yesterday I took the fusebox apart again and coincidentally opened it the exact same way as depicted. Lots of crimping with pliers and hammering. As a matter of fact I jumped on the forum just now all excited to upload pictures and share with everyone how to do it. A day late! My copper wire was broken IN THE EXACT SAME SPOT as in that picture http://forums.corvetteforum.com/1582973586-post85.html
I feel if everyone's breaks in that same spot it's a GM flaw somehow and they need to pay for it. Oh well, anyhow... That tutorial needs to be flagged important so everyone with this headlight issue whom doesn't want to pay $500+ can follow it and fix their Vette.
Thanks guys, I love this forum. (my next fix is the Fuel Sending Unit, yes I bought the Vette with these 2 very common problems. But I've already found the step-by-step youtube video for the sending unit)
Old 06-24-2013, 01:02 PM
RLSebring
Supporting Vendor
Support Corvetteforum!
RLSebring's Avatar
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Congrats! The shame also is how much some are charging to repair. My last fuse block I bought was around $275.00 new and you see what little is involved in actually replacing the whole unit, maybe an hour tops.
Old 06-24-2013, 02:44 PM
torquetube
torquetube's Avatar
It's more like ten minutes tops. Five if you'd done it before. New ones come with all fuses and relays installed, so it's really quick.
Old 06-24-2013, 03:05 PM
cclive
cclive's Avatar
So what exactly does this broken wire control??? Is it one of the two lines that control the headlight relay? I think it's just amazing that the wire always breaks in exactly the same place...
Old 06-25-2013, 05:53 PM
bheathcoe_07
bheathcoe_07's Avatar
If the break is always in the same place (at that curve) can we forget the curve and go straight across the top with the new wire?
Old 06-25-2013, 07:57 PM
bheathcoe_07
So I went ahead and decided to tackle this issue myself. Especially after the dealer telling me it was $535 for a whole new fuse box! Big thanks to senseoftouch for his step by step. Only thing I did different was use tin snip for the un-swegde portion. Made several cuts in each one and the screws came right out. Was able to hammer them back in afterwards. And because of my OCD took a pic on all the fuses in place, then took them out and laid them in order on my workbench. Also used stranded wire because it was easier to bend. Took about 1 1/2 hours but I'm all good now and spent a mear $12 on this fix. Cost of a 12 pack .
Old 06-25-2013, 08:04 PM
RicK T
RicK T's Avatar
Stranded wire was one of my thoughts as I followed this issue over the years. Haven't seen anyone use it before you though. Makes sense if the solid wire has a problem in the same spot in all the boxes.
So, is there a difference in the performance of solid wire vs. stranded wire, electrically speaking? TIA for any info you may have.
Old 06-25-2013, 08:18 PM
bheathcoe_07
When I went to purchase the solid wire and explained the reason behind it the guy at Home Depot said the stranded was better because of flexibility (when expanding because of the heat) and easier to bend. I had 14G stranded in the garage, stripped it down and took out three strands which I wrapped together. When putting it in place I used a very small flathead screwdriver to pop into place and hold down when I bent the wire. Really was much easier than anticipated.
Old 06-25-2013, 10:28 PM
torquetube
torquetube's Avatar
I think the curve is there for strain relief. Going straight would likely make it _worse_.
It's probably sufficient to grind out the little plastic grid square where the curve is. That would give the wire room to move.
I wouldn't mess with stranded conductors. The fuse box has punchdown terminals. They make good connections but you have to use exactly the right gauge wire, or else you'll have traded one source of intermittent continuity for another.
Old 07-14-2013, 05:18 PM
Jimbo 89
Jimbo 89's Avatar
Originally Posted by DSOMC6
Yes Jim, the cover is just snaped in place. A small flathead screw driver to gently pry it apart works fine. I had to pull mine apart to get to the fuel pump wire that was intermittently shorting out. Wire and connector looked fine once I opened it up. So I just bent the connector back for more snug fit, a little dielectric grease and it was good to go.
If you have to pull wire(s) loose, there are plastic locks on the side that hold the connectors in place. Be careful not to let other wires escape as it's a cluster**** of wiring. Better yet take a couple pics so you know which wire goes where just in case one escapes.
That seems to be the problem I am continuing to have. The fuel pump wire. The previous owner replaced the entire fuse box, but the problem persists. NO START. I just pop the hood, wiggle the fuse box and it starts right up. I guess my problem is where the fuse box connects to the wiring harness. Any help appreciated, Jim
Quick Reply: How to Remove c6 fuse/relay box
