ABS Control Module
Old 07-27-2012, 11:51 PM
sammy burks
Support Corvetteforum!
sammy burks's Avatar
Default ABS Control Module
ABS Control Module. Does any one know if a used ABS control module can be installed & programed so it will work in a different car.
Old 07-28-2012, 08:53 AM
BEZ06
BEZ06's Avatar
What model year C6 do you have??? There's nothing in your profile that shows anything about you or your C6.
The 2005-2008 have an ABS made by Delphi. You need the compatible parts - EBCM, BPMV, and wheel hubs with the Delphi wheel speed sensors.
In 2009 they switched to ABS units made by Bosch.
So.....you should be able to swap units from a 2005-2008 to another C6 in that model year range, or from a 2009+ into another 2009 or newer C6.
Bob
Old 07-28-2012, 09:43 AM
erick_e
erick_e's Avatar
St. Jude Donor '13-'14-'15-'16
I believe some of them can be. Here is a thread on how to add launch control to your 09.
http://forums.corvetteforum.com/c6-t...-corvette.html
Old 07-28-2012, 01:18 PM
sammy burks
Bob
The GM dealer told me that even if the abs moduel comes from the same year car 06 z06 & is installed in same year, model, that will not work the ven# has been burnt in to the moduel & can not be changed.
Old 07-28-2012, 01:50 PM
BEZ06
BEZ06's Avatar
I'm not positive, but I'm pretty sure that is not correct.
I'm pretty sure you can program a used one into another car.
Bob
Old 07-28-2012, 02:32 PM
cartwheel
cartwheel's Avatar
Are we talking about EBCM here? Because I'm not seeing a ABS only control module in my 2007 service manual.
Old 07-28-2012, 04:27 PM
X25
Sr.Random input generator
X25's Avatar
Received 1,463 Likes on 1,020 Posts
If it's a 2009+ model, I have the control module available:
http://forums.corvetteforum.com/c6-p...-cylinder.html
Old 07-28-2012, 05:44 PM
sammy burks
Yes its the EBCM which is the same as ABS moduel.
To ABS Control Module
Quick Reply: ABS Control Module
