Question on installing ZO6 output shafts
Old 07-10-2012, 08:08 PM
07blkvette
07blkvette's Avatar
Default Question on installing ZO6 output shafts
If installing ZO6 output shafts what else would be recommend to change when doing the shafts?
Old 07-10-2012, 08:50 PM
carlrx7
carlrx7's Avatar
St. Jude Donor '08-'09
axle nuts, if it needs rotors, brake pads, grease toe rod ends if possible. new diff fluid, since some will most likely leak out when you pop out the cv.
-Carl
Old 07-15-2012, 03:04 PM
Rick@RKT Performance
Supporting Vendor
Rick@RKT Performance's Avatar
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Here is my old thread with all the parts list for the conversion.
http://forums.corvetteforum.com/c5-g...-z06-guts.html
__________________
To Question on installing ZO6 output shafts
Quick Reply: Question on installing ZO6 output shafts
