Wheel spacing for my GS?
Old 07-12-2012, 09:48 AM
TexVette25
TexVette25's Avatar
Default Wheel spacing for my GS?
I want to change the stance of my GS a little bit and I'm going to space the wheels out to beef her up. I know I need to buy longer wheels studs (ARP im assuming) and it was recommended to get the spacers from Baer but I'm not sure length and width for the front and back. Help!
Old 07-12-2012, 10:29 AM
Speedforhire
Speedforhire's Avatar
Looks great as is, but I suggest swapping to a set of black ZR1 wheels instead (19/20).
Old 07-12-2012, 11:04 AM
LEAVINU
LEAVINU's Avatar
..... I think it's perfection as it sits. Matter of fact I may mirror it exactly for my GF's GS.
As for spacing I run 5/16" spacers but I dont have the wide body so its hard to say. The 5/16" put my wheels perfectly aligned with the fenders though. Being as low as it is and the wheels pushed out it looks much meaner from what I've been told.
Old 07-12-2012, 11:47 AM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
If you want to get a feel for how it will look, just stack some 1/2" ID flat washers on the lug studs and put the wheels and lug nuts back on. But first remove the rotor retaining clips.
DO NOT DRIVE YOUR CAR WITH THE FLAT WASHERS INSTALLED.
You will have to move the car a short distance to let the suspension settle back to normal.
Old 07-12-2012, 01:25 PM
TexVette25
TexVette25's Avatar
Thanks for your responces! I guess my question how much is a safe amount to space the front and the back. I was thinking 1/2 inch front spacers and 3/4 back?
Old 07-12-2012, 02:08 PM
LEAVINU
LEAVINU's Avatar
If you're not road racing the thing and use good studs, like the ARP's, then those shouldn't be an issue. Definitely get a quality spacer too though. I opted for some cheap Pep Boys ones to fit my brakes but never got better ones and eventually the spacers caused me issues with the brakes. In short, those cheap spacers were so poor in quality that torqing the wheels on was crushing them along with aggressive driving over time.
Old 07-12-2012, 05:07 PM
MINI&aVette
MINI&aVette's Avatar
This is where you want to get your spacers
http://www.motorsport-tech.com/
To Wheel spacing for my GS?
Quick Reply: Wheel spacing for my GS?
