Few Mods To Enhance Catch Can Condensation
Nice mods, and undoubtedly will help. I do think there's also a lot of benefit to just using long, level runs of tubing from the engine to the catch can. My runs are three feet long to the catch can, and after driving it, there's a noticeable difference in how hot the hose is near the engine versus near the catch can. I've run about 10000 miles with a stock catch can and my intake is dry with just a very, very light haze on the surfaces that barely stains a white cloth.
Former Vendor
1 Post
St. Jude Donor '10-'11-'12
enhanced surface area and an adequate distance from intake to exhaust is what you need for very effective can.
that's unacceptable, there should be no film at all
How about just a bracket to be able to install catch can between right hood hinge (passenger compartment) and the electronic component about 2-1/2" apart? I have a picture of a 2" catch can installed there, but it's narrower than most. I'm going to gamble ordering an AMW catch can, which I really like because if I order a black one, everything is black, including the bracket and fittings, for a stealthy installation. I'll have to test installing the bracket just above the electronic component (don't know what it is, but can't be relocatead). I've always bought EE catch cans, but couldn't get it installed this time with the baffle, so returned it. The location I mentioned is perfect, because is significantly cooler than next to the engine, and the long hose runs help further with that. Unfurtunately, the EE catch can is even wider than the 2-1/2" of the AMW. I suspect 3", so might not even work with a bracket. Hope you can test it there and give us your comments. Good job.
I don't know if that film is from the thousand or so miles I put on the car before the catch can install, or from the 12000 miles afterwards, but it is minimal enough and I've driven it hard enough to be satisfied that it is working "well enough". I've got lots of other items to address that are of a more critical nature than removing the last little bit of blowby, IMO.
Did you use any medium to help transfer the temp from the can to the heat sink ?
In moving the can, how about moving it forward by the radiator ?
1 Post
Today I just messed around with my system. Nothing like you did with yours though. I simply added to the length of hose coming from the motor. I now have about 10-11' of hose before the "dirty" air gets to the catch can. I'm hoping it's enough to cool down the vapor some. I have it routed along the side of the radiator on the passenger side, then in front of the airbox to the other side of the radiator. Then along the side of the radiator along the drivers side, then along the top rear of the radiator back to the catch can. It basically makes a complete 10-11' foot loop around the airbox and radiator. I also placed a temporary air compressor filter inline AFTER the catch can, just to see if it catches any additional vapor.
1 Post
Nice attempts to cool the incoming blowbys and use of inline filter!
No offense, ever wonder how much rubber hose weights? My Gumbies weights less than the tires!
Aluminum is a great heat sink, way lighter and you can accomplish better results with shorter runs!
I'd considered different locations and make piping runs with aluminum tubing, but instead, I opted for simplicity, staying at the same foot print by isolation from heat source and using heat sinks to rid the heat! Also modified internal surface to generate longer dwell time for blowbys to condensate.
I am fairly satisfied with this project other than to machine an duplicate of the stand off with G10 and call it a day, so I can move on with other projects I have planned for my Vette!
I plan on moving the catch can next to the radiator on the passenger's side, like someone did -HERE-
1 Post
May I suggest trying next to the hood hinge, right next to the airbag sensor. I'm pretty sure that can fits there, but measure it; it has to be 2-1/2" in diameter or less. I'll try with the AMW I have on the way, which is right at the max. It's much easier to drill, and to remove can for evacuation. And you can route the hoses much neater as well. But if not, the location you linked is my second choice. Last choice is attached to the baffle (I have a picture somewhere of exactly my can on that location). I can drill next to the airbag sensor with my Dremel attachment, but the linked location requires an angled drill attachment for sure, and I'd have to buy one. Good luck, and please keep us posted.
I should have it finished up tomorrow, hopefully.
That's a good idea too man. Make sure to document your project with pics . My can requires 2 screws from inside the bracket, so have to go with holes myself. I'll probably put blue loctite on the screws, to prevent them from getting loose over time. Hey, could you measure your can's diameter to see if I have a chance to install mine at the same location? Many thanks. Looking forward to your finished project.
How about between the fuse box and the battery? The can is vertical, and the long hose run is beneficial and are nearly horizontal. It's cool there, and fabbing the bracket took just minutes. The bolt for the hood hinge holds it tight.
1 Post
Indeed . But it's just a matter of tilting it ever so slightly. The problem is the bottom of the radiator plastic shroud is in the way. Otherwise it'd barely clear perfectly vertical. I have to run a test with the top fitting installed, to see if I can raise it a little to clear everything, or just put a piece of foam tape at the radiator shroud to avoid direct contact. Plastic doesn't get hotter than the can, so no worries there. With the foam tape, it shouldn't make any noises. But I'm almost sure there's enough clearance on top to lift it slightly. The good news is there's a lot of room under the can to drain it with a plastic cup without having to remove it. Have to work on other cars, but will finish this project next week, and keep the gang posted. By the way, the screws are pretty hefty, and the bracket holes are angled, so you can put all the pressure you need to tighten them. Not worried at all the screws will come loose. And the nice thing about this can is you cannot see any screws at all; looks factory. And functionally, it's the best I've seen by far, and I had EEs before. More than enough for a NA engine, especially in a relatively cool place. Good day gang.
1 Post
Mine on my Firehawk seems to work fine, although I may move that one too. Right now I have it bolted to the engine with very short leads. I don't know what one is "better" though. I did read -THIS- thread awhile ago and The Bat Car stated that his Mike Norris can worked good.
The Mike Norris/CCA can was completely effective at all levels of operation with mild builds and performed well with all up until a large FI build or radical big cube test and then only a small amount was getting through. Increase the size by another pint allowing the velocity of flow to slow even further, add a integrated check valve with flow control, and it would be second to none.
1 Post
With the exception of removing POR15 coating on mounting arm to enhance direct heat dispersion at a latter date; the following changes (some are obvious with the others within) I just completed, sum up my version of the catch can mod:
1. Machined new and improved G10 Standoff
2. Machined two one piece .050" thk. titanium spacer to spread loads in cavity of Standoff in place of the soft 304 cres.
3. Bored IDs from .187" to .280" in 90* elbow with no step at cross angle transition.
4. ID within inlet custom heat sink/radiator fitting now has .060" counterbore to prevent condensated oil to drain back:
Happy modding all! :P
Here are my pics. Boy, the black paint sure doesn't seem to match in the camera flash!
1 Post
I plan on picking up a 3/8" vacuum cap to put over the end of the drain hose. This will keep oil from dripping out after I drain the can. What I didn't show was the glass fuel filter I have in place between the outlet of the can and the intake manifold. I am hoping this will be just a temporary thing so I can monitor how clean the vapor is exiting the can.
ive got some experience in this area and agree with not bolting it to the head.
ive got about $50 tied up in mine with the sight tube on the side and mesh inside, drain on bottom, catches a good amount.
