PFADT Urethane suspension bushings just installed in C6
4th Gear
My 2009 C6 is a Coupe with paddle shift and Magnetic Ride. It is my street/track car. For the track I run a set of 2003 rear Z06 Speedline 18 x 10.5 inch wheels from my old Z06 all around with Toyo Proxes RA1's. 275 up front and 305 rear. The car handles very well and I can lap in the 1:35 range at WSIR. The AT fluid temp never exceeds 235 F even on a warm day with heavy lapping for 20 minutes.
Last time at Willow Springs International Raceway I noticed that at the onset of threshold braking at 130 MPH the car would dart right or left a bit too much for comfort.
I decided to upgrade the 4 year old stock rubber bushings with a PFADT urethane set all around. As before, I had the alignment set for maximum negative camber front and rear (about 1.7 degrees).
Driving on the street I immediately noticed that the steering came alive. My fingers were now connected to the road. This is the cure for numb Corvette steering! I can hardly wait to get back on the track to experience the further expected benefits in cornering and braking precision. Once I do, I will post an update.
4th Gear
Reply to questions on PFADT urethane bushing setup
The Z06 wheels fit well, however the 305 mm Toyos do rub the fenders slightly in the turns
Keep us updated on your progress as you spend more time on track!
